Question about Broderbund Print Shop Pro Publisher 11
Unable to install Print Shop verison 11 on my Window 7, why?
    President:
  • 2,340 Answers
Print Shop Pro Publisher version 11 was built for Platform OS: Windows 98 / Me / 95. It is an old software which is not for Windows 7(x86 or x64) OS. This is due to software compatibility issues with Windows 7 ie an old software running on a newer OS Platform.
You have to get a newer version which is compatible with Win 7.
Hope it helps.
Posted on Mar 12, 2011
I have Broderbund Print Shop version 11. How can I open docs on windows 8? Leanne
Sorry I don't think there is a solution. Windows 8 doesn't run version 22 either. I did load version 23 on it for a while but it was limited in size of document. I had to remove it. Am looking for another product now. I guess we have to have an old computer for an old program.
Nov 27, 2012 | Broderbund Print Shop Pro Publisher 11
Is it possible to install Print shop version 11 on windows 7?
according to their site its not compatible to Win 7 means it can install but not all most all the functions are available but they are up to release a new version with compatible to win 7
Sep 02, 2011 | Broderbund Print Shop Pro Publisher 11
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
HELP I have used Print Shop for 20 years and I'm so dependant on it I have been using Version 11. We were in a car wreck and our vehicle burned...with my laptop inside! I purchased a new...
So often computer software's are improvised by the manufacturer into another version much innovative than the prior. Usually, software updates may least improve the feature functionality only as a compatible version to another computer. The versions listings on the software are identification number provided by the manufacturer to distinguish between several programs of similar or prior establishment. Computer devices require a compatibility inspection prior to acquisition to achieve integration into the existing system. Usually new programs require inspection for compatibility to an existing computer prior to acquisition. In which instance, a new computer sets the alternative arrangement of compatibilities. First, the new computer is least expected to be compatible only encountering outdated software programs as a likely observation. A new computer continues to function with prior software's because is compatible. Usually, new software's perform better with newer computer as compatibility matches or feature functionality requirement to attain user experience. Print shop should perform as before with windows 7 computers only with compartibity that is observable on capability to be downloaded on the computer. An alternate arrangement includes acquiring recently innovated print software that would not only be compatible to the new computer but also modernized to achieve user experiences.
Jan 26, 2011 | Computers & Internet
I can't open sig. files on window 7 keeps saying not supported will not allow me to use the software to open either. no matter that i the print shop as default
Print Shop 20 is not completely compatible with Windows 7. For example, when I try to open a Print Shop 20 project on my Windows 7 computer, by double-clicking on the file which is displaying the Broderbund logo, I receive an error message which says, "There was a problem sending the command to the program." And, even though the Print Shop 20 file will eventually open, it actually opens in PrintMaster.
It is, however, possible to force the file to open in Print Shop 20 by doing this:
1. Open Windows Explorer, then find and right click on a Print Shop 20 *.sig file.
2. When the menu drops down, click on 'Open with...'.
3. When the 'Open with' window opens, make sure that there is a check mark in the box next to 'Always use the selected program to open this kind of file'.
4. If Print Shop 20 is displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on Print Shop 20, then click on OK.
If Print Shop 20 is NOT displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on the 'Browse' button.
5. When the second 'Open With' window opens, navigate to this folder
C:\Program Files (x86)\The Print Shop 20\The Print Shop 20
then, click on the tps.exe file.
6. Then, click on 'Open' then click on 'OK'.
This should cause all *.sig files to automatically open in Print Shop 20 when you double-click on them. However, since file associations are always based on the file extension of the project file, it might be necessary to repeat the process above for all Print Shop 20 file extensions.
Hope this helps....
Nov 17, 2010 | Broderbund The Print Shop 20 Deluxe for PC
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Unable to install Dymo 400 on a Window 7 computer
Dymo is not compatible with win 7 so try to find out the correct version to install it
thanks
May 18, 2010 | Computers & Internet
Window media
go to the control panel and repair Windows media player. If its Windows Media Player 11 then it will repair if is not then get it here http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx Might as well have the latest.
Sep 10, 2007 | Audio Players & Recorders
Broderbund Print Shop Pro Publisher 11 Logo
688 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
