Question about Tokina 10-17mm f/3.5-4.5 AT-X 107 AF Lens
I brought a tokina 10-17 mm lens primarily for underwater photography. When I went to use the lens for the first time the zoom ring came away from the lens housing, leaving my lens in two pieces. On closer inspection I found that these parts are held together with a piece of black tape and glue. I am told by the company who supplied the lens that this is not a manufacturers defect and as such not covered under warranty. Is this the normal way in which these lenses are assembled and if so wouldn't this make it a manufacturers defect. Please advise this is a brand new lens brought through DWI
2 Suggested Answers
MarkDay
  • 111 Answers
SOURCE: Does Tokina-12-24mmF/4Pro DX complies with Nikon-D3 FX Format
Barrel distortion like you describe can always be a problem, especially at ultra-wide focal lengths like yours at 12mm. Some of this can be compensated for in software... Adobe Photoshop CS2 and Elements do a reasonable job, IMO, Bibble Pro (www.bibblelabs.com) does even better, especially with the 3rd party plugins like Percy perspective correction. These are things we have to live with when we have smaller sensors and ultra-wide angle lenses. There is nothing wrong with your lens, you will probably find that this distortion is minimized if you use a longer focal length (say 14mm) and/or stop down the lens a bit.. try f8, wide angle lenses have huge depth of field.
Posted on May 20, 2008
I need a new front element for a tokina 12-24mm, where can I get one from and can I do the repair myself?
Do you have a lens collimator and other equipment needed to ensure proper alignment of the element? If you don't, send the lens back to Tokina and have them replace the element.
Feb 23, 2014 | Tokina 12-24mm F4 Pro Ii Zoom Lens For...
Need lens (up to 200)
Lens needs are determined by the type of photography one shoots. Example, for my needs I use three prime lens, 35 mm, 50 mm, and 100 mm. Sold all my zoom lens purchased primes.
The question is what are you attempting to capture? On a zoom lens look towards a constant aperture, not one when we zoom the aperture changes.
Cordially
Jan 25, 2014 | Canon EOS Rebel 2000 35mm SLR Camera
Is there an adapter for Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens to fit to panasonic gh2 m4/3?
Perhaps. Tokina makes lenses with a variety of mounts. If the lens already has an m4/3 mount then you won't need an adapter at all. Some Tokina lenses take the "universal" T-mount. In this case remove the current mount and put on an m4/3 mount. If it has some other fixed mount, m4/3 adapters are available for some of them. It all goes back to the mount already on the lens.
Jun 20, 2012 | Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens...
Need information and Instruction Manual for a Vintage Bushnell 300mm camera lens
This is not a zoom lens, it is a fixed focal length of 300mm telephoto, so the focus ring will not slide back and forth, merely rotate. It is also manual focus. If you google it, you may find a manual, but doubtful - best bet is to get a book on basic photography and read up on telephoto lenses there.
Update - allegedly made by Tokina, so should be a reasonable lens.
Apr 01, 2017 | Bushnell Cameras
Over exposure in cold weather
I suggest that you contact Tokina directly to find out what range of temperatures your lens is designed to work across.
Your expression "cold weather" is an imprecise term; where I am in the UK means at worst down to a few degrees below freezing and usually a bit above, but when I'm in Moscow they don't consider it to be cold until the temperature drops to around minus twenty-five Celsius.
Depending on where you are, your lens may simply be unable to cope with what you describe as cold weather but you won't know until you have the specifications from Tokina. If it turns out that your lens is not performing as intended, then the manufacturer will be able to suggest remedies to you.
Sorry I cannot be more specific but Tokina do not appear to have published the range of operating temperatures in the public domain.
Mar 01, 2010 | Tokina 12-24mm f/4 Pro DX for Nikon
May 20, 2008 | Tokina 12-24mm f/4 Pro DX for Nikon
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Apr 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
35mm Pantex Camera model # ME
That's the focal length of the lens. If there're two numbers, then the lens is either a zoom or a "vari-focal" lens, meaning the lens can change focal length from one end to the other. In this case, the lens can change its focal length from 150mm to 750mm, either by turning a ring or pushing/pulling a ring.
BTW I wasn't aware Pentax had a zoom that long. Are you sure it's not 75-150?
Dec 14, 2007 | Pentax Cameras
Tokina 35-300mm af zoom lens
Unless you have extensive experience, this is best left to professionals. If you didn't spend much, then you could "learn" on it, but if it is something you really value...don't do it.
Oct 29, 2007 | Tokina 35-300MM F4.5-6.7P KAF Lens
Tokina 10-17mm f/3.5-4.5 AT-X 107 AF Lens Logo
66 people viewed this question
Top Tokina Cameras Experts
Steve
Tony Parsons
Tony Parsons
Are you a Tokina Camera Expert? Answer questions, earn points and help others
