Question about RCA Televison & Video
Tv is not coming on when plugged - RCA Televison & Video
  • RCA Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck...
Posted on Mar 11, 2011
Have power to my tv but screen will come on
Unplug the TV from AC mains wall socket. Plug it back after 5 minutes or so. this must make the TV to a hard reset. Try this.
Jun 05, 2012 | LG 60PS60 60 in. Plasma HDTV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I have a 32" LG
Hello Undernet01,
Yes, it's very simple. Connect the computer speakers to the headphone socket on the TV, then run a separate audio cable from the PC to the TV. A PC monitor cable wont carry an audio signal so you need to connect an RCA type cable or similar - depending on whether you have corresponding audio OUT sockets on the PC and audio IN sockets on the TV.
You will then have sound from both the PS3, the PC, and the TV on the computer speakers. The TV speakers will automatically switch off when something is plugged into the headphone socket.
Simples as pies.
BElectric
Dec 26, 2010 | Computers & Internet
Av27120 jvc tv on timer lamp flashing. cannot turn on tv.
I need a solution for this problem..I can't get the tv to come on to go into the menu and clear the timer...Someone have any helpful info...I have the comcast box on the tv..I took everything off the tv
and plugged it in thinking atleast the snowy screenwill come up and then I could see the menue and fix the timer but that didn't happen. Left tv plugged in and cable hook ups on figured eventually the timer would clik off and tv would come back on..No such luck....Can anyone help me with this problem
Dec 12, 2010 | JVC AV-27120 27" TV
I plugged my ps3 in my olevia tv and it comes up
Nothing is wrong with it. It's only compatible with 24 Hz, 25Hz interlaced, 30Hz interlaced, and 50Hz.
Feb 25, 2010 | Televison & Video
Where to plug in the home theater on the tv?
If you REALLY want to plug your tv into your home theater system there should be rca (red and white) jacks on the back of the tv that say "audio out" or "speaker out" thats your tv's audio output. which is where you would plug in the TV to your home theater system.
But there's really no reason to do this and its not the most desirable way to set u a home theater. Sound doesnt come from your tv, and therefore your tv shouldnt be plugged into speaker (unless you have old school wal cable) sound comes from your cable box, DVD player, VHS, Xbox, Ps3 etc. the sound comes from your source, and these sources should be hooked up directly you your home theater reciever
Oct 01, 2009 | Dynex Televison & Video
Blue screen only
double check the input, the simple way is using a good DVD player and good A/V Cable. plug in the A/V cable in DVD A/V output, then plug the other plug into TV A/V input. Then set your tv to AV input. if nothing comes out even though the dvd player is playing. The TV AV switch maybe damaged.
Jun 02, 2009 | Prima C2012 TV
Tv wont come on had a powersurge hasnt come on since why?
TV fuse open /replace
If same proiblem fuse pop the power IC was shortage.
Jan 03, 2008 | Panasonic CT-32G19 TV
Televison & Video Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
