Question about Sony Playstation 3 (PS3) Console
My PS3 was orginally hooked up using AV cables. I moved temporarily, then hookd it up using HDMI cables. Now back to my original place, how can I go back to using AV cables?
  • Sony Master
  • 3,018 Answers
The same way you did before you moved.
Posted on Mar 11, 2011
  • Iron
    Iron Jun 23, 2011
    I see, that made to much sense.
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
Sound keeps cutting out momentarily on ps3 connected to samsung plasma tv via hdmi cable
Make sure game disk is clean and scratch free. Try and hook up the video with original AV cables (Red,Wht,Ywl) and unplug HDMI.Try another HDMI cable. If none of these help you could have bigger problems. Good Luck.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Powers on but nothing happens
It happened to me too. When you plug in your av cables and are ready to play, follow these steps. With your PS3 off (Red light on), Press and hold the power button on your console. (Do not use the controller to turn it on.) Keep holding the button until you hear a second beep. (it takes about 2 to 3 seconds.) You will notice your screen flickers, then your PS3 will show up on the tv. All you did was reset the PS3 display settings. You can always go back to HDMI or AV cables. Have Fun.
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read my hdmi cable
first hook up the av cable then do your set up then powerdown then hook up your hdmi if not problem message back
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont show or load games
If you originally set up the PS3 with A,V cables it won't work on HDMI even if you set it up to and visa versa. There is a work around but you will have to call tech support. Here is a link at Sony's PS3 tech support that may help also. http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=263
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
