I have a logitech g510 keyboard. some of my keys are sticking. howq do i clean it iwthout breaking it?
    Guru:
  • 196 Answers
Although the manual doesnt cover this as shown here: http://www.logitech.com/assets/32784/g510620-002384002403gsamr.pdf
I did find another person who has done some kind of cleaning for his board. Here is what DEEJAY did. This offers a step by step with photos
http://www.overclock.net/computer-peripherals/170684-how-clean-your-keyboard-literally-logitech.html
Posted on Mar 11, 2011
  • 27,725 Answers
Try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you hould see driver detailsand have options to,update driver,roll back driver,uninstall
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
hope this helps
How do I remove the keys on a Logitech MK700 keyboard to clean properly?
Try using simple flat-head screw driver. It should remove easily, but i don't think that'll solve your problem.You should pry apart your keyboard with screws and use damp cloth to clean the board, as well as rubber buttons. I'm not so certain about that, but you should try it. Dusan
Jul 09, 2014 | Logitech Wireless Access Duo Optical...
Seveal keys stick
On mine I have a couple of keys that stick To unstick them turn thekeyboard upside down and then knock on it just like you are knocking on a door. That pops the leys loose. do not try to pry them loose.
Past that you need to take the leyboard apart and clean. If you have spilled something you have to clean or replace.
Dec 02, 2010 | Logitech Wireless Access Duo Optical...
Logitech cordless keyboard not working properly - keys stick or are delayed
Did you spill something on it or is food lodged in unit if so take apart clean.
Fresh batteries would be good start.
Feb 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
Keys Sticking
no! you don't want to do that if you unscrew the back plate all the plastic suction cups with fall off and you will never be able to type on it, until you place the suction cups back what you want to do is get some WD-40 (the tool for fixing almost everything) or a can of pressurized air with a areosole top and aim it at the key or under it, press it and it will blow every piece of junk under the keys cleaning it.
Feb 09, 2010 | Logitech Wireless Access Duo Optical...
Keyboard misses often. Then suddenly works fine - on and off this happens.Some keys will always work others often miss.
Wireless could be batteries or channel problems. Try the channel button first.
Wired double-check connection, clean KB (or keys) as needed. Most keys can be removed, but be sure not to break them or lose the springs!
for cleaning, check this link...
http://www.ehow.com/how_4850336_clean-computer-keyboard.html
hope this will help you to fix the problem.
rate this solution...
Jan 13, 2010 | Logitech 967437-0403 Keyboard
My logitech wireless keyboard won't type. i
go to logitech support, download setpoint software and follow instructions on setting secure connection. i just did it with mine and keyboard got fixed. your symptoms should be that the qwerty keys dont work but the multimedia, clock and function keys are working. the setpoint software will take care of that.
Nov 11, 2009 | Logitech Cordless Desktop MX3200 Laser...
I use my computer for gaming and when i move around with the arrows they stick sometimes in one of the directions un til i tap that key again, is this common for the classic keyboard 200?
Logitech keyboards are excellent both in quality and longevity.
Make sure some sugary drink has not been spilled on the keyboard.
This will make the keys stick and repeat. I have had good luck with Dawn and warm soapy water. Just make sure the keyboard is completely dry before putting back into service. 1-2 weeks drying time. (IF you dunk and submerge. Only the most severe)
Never EVER dunk a laptop in water to clean the keyboard.
I know I know... but someone will try it. :)
Check to make sure the windows sticky keys are turned off.
Sounds like dirt or a soft drink is causing this repeating pattern you described.
Oct 10, 2009 | Logitech Classic 200 DH968019 Keyboard
Saitek Eclipse II keys are sticking
You can remove the screws on the back and clean the keyboard. It's very easy task to do. Just remember components locations inside so you can reassemble.
Jan 16, 2009 | Saitek Eclipse II
S520 Logitech Keyboard keys are sticking
This keyboard is horrible. Several of the keys stick or will not work.
I called customer support which was not very helpful. They told me to take the batteries out of the keyboard then retry the keyboard and if it still did not work return it to the store I bought it from..
I like the set up of the keyboard but? to bad it does not work.
As I am typing this with my old keyboard because I can not use the the s520
Jan 01, 2009 | Logitech S520 Mouse
Keyboard
you will have to use the Function key, and look at the pause - break button you see that small icon there, that combined with the function key is scroll lock.
so press the FN key and pause break.
Jun 11, 2008 | Logitech Cordless Desktop MX3200 Laser...
Computers & Internet Logo
4,060 people viewed this question
David Payne
David Payne
