Question about Cell Phones
I am trying to put an extended NNTN5539A antenna on my i355 phone, but I can't figure out how to remove the original antenna. I saw on one forum where someone said there was a tool to remove it, then I saw somewhere else that someone said to use a small screw driver. Neither gave very much details, so I'm still lost. Please help!
    New Friend:
    Problem Solver:
Country John doesn't know what he is talking about. There is absolutely no need to be taking the handset apart like that. Removing the original antenna and installing a new one is a very simple process and requires nothing more than a small screwdriver. You are likely to damage the locking tabs and/or seals on the handset case following his lame instructions.
First, pull the retractable antenna out about halfway, so you can flex the antenna to one side or another. Look into the shaft housing the antenna and you will see grooves in the interior. Using a small screwdriver, insert the screwdriver into the antenna shaft and unscrew it. Once it's unscrewed, you will be able to remove the antenna assembly. There will be a plastic sleeve for the retractable antenna, that should drop out if it didn't remain attached to the antenna assembly.
Installing the NNTN5539A is simply a matter of screwing it on by hand.
Posted on Dec 21, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
It's simple. In order to install the antenna, you must do the following:
Using a very small "star" type screwdriver, remove three screws from the base of the unit. Remove the base trim piece. The body of the phone is in two pieces (front and back). Use a knife to separate the pieces by first GENTLY lifting the locking tabs on the bottom of the unit so that they will easily unsnap by themselves, just lift them a little bit, not all the way. Insert the blade along the side of the seam and pry gently.
Slowly remove the back. There will be adhesive tape at the top piece, so work slowly. Notice the locking tabs on the sides, they will come apart by themselves, no need to worry about it.
After separating the halves, unscrew the top of the original antenna, screw the new antenna in place, slide the back atenna opening over the new antenna and snap into place, making certain that the side tabs insert properly. Just use your eyes and common sense. Do not force anything, but snapping the halves back together will require a firm force.
Replace the bottom trim piece and three screws, you're done!
Posted on May 23, 2011
  • Former Nextel Tech
    Former Nextel Tech Dec 21, 2014
    Nonsense, this will lead to damage to the handset, and is completely unnecessary. Stick to giving fixes for gear you actually know something about.
How many wire harness clips connect to rcdlr module on 2007 impala besides the antenna
2007 Chevy Impala Keyless Entry: Keyless Entry Only ...
www.2carpros.com/questions/2007-chevrolet-impala-chevy-keyless-entry
Dec 30, 2010 - CHEVY KEYLESS ENTRY ... 2006-2007 Chevrolet Impala, Monte Carlo ... Remove the clips holding the RCDLR antenna wire at the RCDLR module and along the "A" pillar. 5. ... Connect the new antenna to the RCDLR antenna module. 11.... The existing antenna is grounded into another wiring harness.
TPMS and key FOB range problems - LS1TECH
ls1tech.com/forums/ls4.../719926-tpms-key-fob-range-problems.html
May 24, 2007 - 2006-2007 Chevrolet Impala, Monte Carlo ... Remove the clips holding the RCDLR antenna wire at the RCDLR module and along the "A" pillar.
Buick Workshop Manuals > Lucerne V6-3.8L (2007 ...
Dec 01, 2015 | 2007 Chevrolet Impala
How to free motorola i355 from the lock
Hi. do you want to make your Motorola i355 free from network lock? If so, you need to unlock your device by entering an unique unlock code. You can get the unique unlock code for a Motorola i355 from TheUnlockArena.Com at affordable cost with easy unlocking guide. Good luck mate.
May 30, 2014 | Cell Phones
I have i355 motorola phone bought it from my freind from canada but in my location its not working, so please tell me how will it work in my country
May be the mobile is locked with a Canadian Network.Try inserting other sim cards and even then it is not working then definitely your mobile is locked.You need to enter the unique unlock(subsidy) code for the mobile to break from the restriction.You can get the unlock code for your Motorola i355 from http://www.theunlockarena.com/motorola-i355/rs16wp9/ and remove the network lock easily by specifying the country and network to which the mobile is locked to.
May 07, 2013 | Motorola Mobility i355 Cellular Phone
How do i change the lauguage from spanish to english on the i355 nextel phone?
From the main menu, select Settings >
Display/Info/Language
May 13, 2010 | Nextel i355
go to menu options to setup and you should find a language option.
Mar 23, 2010 | Nextel i355
My phone is restricted. It says "ready" on the display. How do I unrestrict it?
You are having an issue with your service. Nothing you can do manually. Call Nextel. If your carrier, "Nextel" isn't present on the display then you have a service issue. Ready means that an emergency call will work but you can't make or receive calls.
Apr 15, 2009 | Nextel i355
Motorola i95cl
unfortunately the i95 uses a 32k sim card and your i355 uses a 64k card...
Apr 13, 2009 | Motorola Mobility i95cl Cellular Phone
NetGear WGT624 Antenna
i would just think you twist the antenna
Dec 30, 2007 | NetGear WGT624 Wireless Router
Cell Phones Logo
148 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
