THIS COMPUTER ALWAYS RESTART, BIOS MISSING, CAN'T DISPLAY. THANK'S
  • Karabo Moabi Motingwa
    Karabo Moabi Motingwa Mar 11, 2011
    how long have you been using your computer?
    President:
  • 2,340 Answers
If it is a PC Set, try replacing the CMOS battery (CR2032 3v battery).
Posted on Mar 11, 2011
Reset bios hp pavilion m7750n
  1. Turn on or restart the computer.
  2. While the display is blank, press the f10 key to enter the BIOS settings menu.
  3. Press the f9 key to reset the BIOS to the default settings.
  4. Press the f10 key to save the changes and exit the BIOS settings menu.
Feb 22, 2017 | HP Computers & Internet
How to restore corrupted BIOS of presario cq60 laptop
Whenever you upgrade the BIOS on your notebook, a copy of the previous version is stored in the HP TOOLS partition of your hard disk drive. Many HP notebook computers have an emergency BIOS recovery feature that allows you to recover and install the last known good version of the BIOS from the hard drive, as long as the hard drive remains functional. This emergency recovery feature is separate from the BIOS and is designed to work in the event of a catastrophic BIOS failure.To recover an earlier version of the BIOS on your notebook:
  1. Turn off the computer.
  2. Plug the notebook into power using the power adapter.
  3. Press and hold the Windows key and the B key down at the same time while the computer is off.
  4. Still pressing those keys, press and hold down the Power button on the notebook for 3 seconds and then release the Power button and the keys. The screen remains blank for about 40 seconds before anything appears on the display. You might also hear beeping sounds. Eventually, an HP BIOS Update screen displays.note.pngNOTE:If the computer fails to display an HP BIOS Update screen, press and hold the Power button for 5 seconds to turn off the computer. Wait 5 seconds and try again. If, after repeated attempts, you cannot open the HP BIOS Update screen, your computer does not support this function or it has a hardware problem that is preventing the tool from opening.Figure 1: HP BIOS Update screenc03376208.jpg
  5. When the BIOS has been recovered, a Continue Startup button displays and timer counts down. You can click Continue Startup to restart the computer or you can allow the timer to reach zero and the computer will restart automatically.Figure 2: HP BIOS Update screenc03376209.jpg
  6. After restoring the BIOS, if the computer repeatedly displays a message that the BIOS has been reset, then perform the steps in HP BIOS Application Selected is Corrupt or Missing .
  7. After restarting, Windows may display a message stating that the computer was improperly shut down or that a boot problem was detected. Read and respond to the screens to continue.
Sep 22, 2012 | Maxtor Personal Storage 3200 (U01E200) 200...
Foxconn nt-a3700 does not power up
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps
Jun 20, 2012 | Foxconn nt-A3700-0H0WBANA Black Mini /...
Screen displays low illumination.dvd drive not functioning.tv ok, av in ok.
Screen Display Issues:
Go to the BIOS. Once you power on the laptop immediately hold down the F2 key then BIOS will show up. Try to check in BIOS if the display has low illumination if yes then try connecting your laptop to an external monitor then toggle the display to the external monitor. If the display from the external monitor is fine then it means the LCD has issues and needs replacement. But before going into any LCD replacement try to update the BIOS version first.
DVD Issues:
Check first the DVD icon in My Computer window. If missing then kindly do this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318
Delete the upper and lower filters.
Uninstall the DVD device driver from device manager.
Restart the computer.
Check BIOS if ODD or DVD is present. If yes then F12 boot to DVD if failed replace DVD drive.
If the DVD not present in BIOS replace DVD.
May 28, 2011 | Computers & Internet
The computer willnt come on.The green light is on I CAN HEAR THE MOTOR RUNNING but nothing on the screen
hi,
try removing the battery and disconnecting the main power. keep idle for a couple of hours.fit everything back and try?
Feb 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Ntdlr missing and lost bios password
Hi dear do one thing .. Repair your XP.. in set your XP cd .. boot from CD there option call repair
Thank you
Imran
Pls give you me a rank as possible
Apr 16, 2009 | Acer Aspire 5100 Notebook
Bios problem
Sounds like the wrong BIOS programme has been installed. Not a lot can be done about that apart from removing the BIOS chip and reprogramming it with an EEprom Programmer. Purchase a new motherboard is the answer.
Mar 12, 2017 | Intel Computers & Internet
I need to shut down spy sweeper and reinstall - how do I do that?
Restart your computer--> black screen--> after the Bios check (is always the 1st step)--> start pressing the F8 key repeatedly--> Windows boot menu will apear--> use the arrows--> Safe mode
It will look different from you normal Windows (don't worry about this)--> go to Add / remove programs--> Uninstall your spysweeper program--> restart your computer normally--> install your program normally
Nov 11, 2008 | Webroot Spy Sweeper (spysweeper) for PC
My windows alwyas restart & recovery bios
orangmedn
pc r restart for several reason like power supply problem, over heated, os problem. if ur pc restart when u try to access any drive or insart cd or dvd in drive means ur power supply is faulty. and if it restart after a fixed time (approximately) means over heated. (u reinstall xp so operating system is not infected.) if one of above symptom r their then no need to update bios.
2nd if some problem heppen during ur bios update and it not wirte properly and u restart ur pc in this situation the ur pc can not start and result is no display condition. if it happen then contact with any mother board repear centre or mother board service centre. (because if bios program r corrupt it need to repalce or rewite).
(**2nd time if u update any BIOS be Cautious. at first take backup then update. if any problem happen then restor with backup copy, then restart ur pc. until u sure update successfully do not restart ur pc).
Jul 10, 2008 | MSI PM8M-V Motherboard
Installing windows xp pro
you need to have a windows cd.
Then you need to enter your bios and change the boot order
to boot from cd before hdd.
If you need more asistance, let me know.
Mar 12, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
