Question about Kirby G4 Bagged Upright Vacuum
I have been helping an elderly couple. The belt on the carpet sweeper appears to have come adrift. can I reconnect it for them and how? Not sure that it is this specific model, but it looks like the picture. Les Auckland New zealand
I have model#UD40350 total pet compact. The lower vacuum brushes don.t turn.
Hi! It sounds like you have a broken or stretched belt. The belt controls the brush roll. If you are using the vacuum on carpet, you need the brushes to spin to agitate the carpet fibers. Below are step-by-step instructions on how to replace your belt. I have also included a link to the instruction manual if needed.
1. Lay cleaner flat and flip to expose nozzle base. To remove nozzle guard, use Phillips screwdriver to remove the screws.
2. Lift and remove brush roll and dispose of old belt if you see one.
3. Slide belt (style 19) onto motor shaft.
4. Place new belt on area of brush roll without bristles.
5. With new belt in place, pull and slide brush roll into nozzle making sure that the brush roll end caps are in the correct orientation.
6. Replace all screws to replace nozzle guard.
http://dirtdevil.com/file/898/
Hope this was helpful!
May 06, 2014 | Dirt Devil Dynamo Pet Bagless Upright...
Vacuum wont spin when on carpet but will spin if tilted off the carpet
Remove the bottom plate of the sweeper. Remove the sweeper brush roller and clean the end bearings of debris. Oil the bearings lightly with 3-1 oil or similar machine oil. Clean the motor shaft with alcohol as well as the brush drive area, and the inside of the drive belt. Test on a carpet for improvement--if still stopping, replace the rubber drive belt. Hope this helps!
Nov 21, 2010 | Bissell 3920 Bagless Upright Vacuum
I need to replace the belt I bought a new belt and I can't get the belt back on
On this page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
there is a video at the bottom on changing belts on a Kirby
Sep 23, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Belt tensioner overheated and doesn't keep belt tight enough
Looking at the owner manual, there is no tensioner assembly.
If the motor is fixed in place and not loose, then you either have the wrong belt, or the brush roller is not properly installed, or the brush roller is worn out where the belt goes around the brush roller.
Dec 16, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
The brush on my dyson ds14 will no move.
Can u turn the brush by hand with the vac off. Sounds like a bushing on the brush is siezed or mabe the belt is worn out and too loose. Try replacing the belt
Jul 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brushes won't spin on carpet
belt is stretched replace the belt and all will be well
Jul 22, 2008 | Hoover U5753-900 WindTunnel Bagless...
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
Kirby G4 Bagged Upright Vacuum Logo
14 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
