Question about HP Deskjet 3845 InkJet Printer
My HP Deskjet 3845 printer had a paper jam and it was removed. It still says it has a paper jam and will not print. How do i fix this?
  • HP Master
  • 4,340 Answers
It sounds like your issue is a sensor is still not happy. Several things happen, but Long story short, you need to get REALLY GOOD LIGHT, get the printer on a table where you can work on it.....
So you need to inspect the entire paper path for foreign material, like torn paper. the sensing typically happens with little plastic levers. These levers get pushed out of position, and force a false indication. any dislodged lever needs to be put back, not necessarily an easy task....
Fortunately, most issues are some teeny tiny tear off of paper, wedged in somewhere.... Inspection and extraction fixes 90% of this issue....
Don't force anything.
Posted on Mar 11, 2011
Hp deskjet 3845 printer will not print and it is no paper jammed, it is installed properly
it sounds like your printer is not connected to the pc or laptop,check the USB cable properly.another problem is paper jam or which leads to qeueing of docs to be printed.
Mar 01, 2013 | HP Deskjet 3845 InkJet Printer
I have a hp deskjet 3845 that says it has a paper jam however, there is no paper in it at all. Is there anything i can do b/c i'm about to drop it down the stairs. I've read a few other questions/answers...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever. get more help and information for HP Printer Support hope this helps you.
Thanks
Michel
Mar 03, 2011 | HP Deskjet 3845 InkJet Printer
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
My Deskjet 3845 printer 'on' button keeps blinking and doesn't print anything.
Usually an indication of a paper jam. Check it thoroughly for any scraps of paper and see what happens.
Feb 28, 2011 | HP Deskjet 3845 InkJet Printer
The green light on my HP Deskjet 3845 is flashing ..when I try to print it tells me there is a paper jam ..there is no paper jam. I have inspected the printer carefully, reloaded the paper. It will not...
i think u should check for peices of paper ,tiny objects etc that might be obstructing the movement of the paper. also check that the print head is not disconnected from the belt you can check this by slidind the print head from side to side and ensure that both of them are moving hope this helps.
Oct 19, 2010 | HP Deskjet 3845 InkJet Printer
Printer pulls paper to right side jams does not print
usually this indicates some foreign object on the opposite side where the paper goes in. Please check to see if you have some small pieces of paper or something else in the paper path area.
also, another possibility is that your pickup roller is missing, dirty or damaged. try cleaning it too.
thanks adi
Dec 01, 2009 | HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 will print the web page, but wehn I try to print a short word document it feeds a sheet through, but prints nothing
plz try by reloading the printer driver and check if you have correct paper size selected in the printer.
Dec 05, 2008 | HP Deskjet 3845 InkJet Printer
Paper jam
Check for anything small stuck between the rollers, like a tiny fragment of paper, or any other debris. Clean it with a can of compressed air, if possible. Hold the printer upside down and gently try to shake off anything that may be inside. Sometimes you may have to dismantle the cover to check properly.
Clean the roller with a damp cloth and wait for the rollers to dry completely before trying to print again.
Make sure you have selected the correct paper type and quality from the printer properties.
Jun 02, 2008 | HP Deskjet 3845 InkJet Printer
Deskjet 3845 not printing properly
it needs a proper service as the moving parts are not moving freely .. or maybe when installing the cartridge you have damagaed one of the sensors .. it can be one of both
Jun 25, 2007 | HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 InkJet Printer Logo
855 people viewed this question
Seeker5211
Seeker5211
