Question about Vacuums
Kirby 5 Model G5D
The neutral/drive mechanism came off. I need a schematic to put it back together and see also which part I might need to replace.
  • Anonymous Aug 18, 2008
    I have the same problem with the same vacuum, same model
  • cat-isha Apr 17, 2009
    I have the same problem!
Is there a re set button on a Kirby. Used the vacuum 2 weeks ago, worked just fine. Went to use it today and it won't start. Any ideas?
Posted on Jun 12, 2010
I need to put the neutral pedal back together
will need to get Kirby engineer to repair, should cost 39 callout+28 for new pedal
Jan 11, 2013 | Kirby G6 Bagged Upright Vacuum
On the rear of the G5D Kirby there is 2 levers that mash with your foot , one is grey and marked with an "N" the other is green and marked "D", what is its purpose
"D" is for Drive, "N" is for Neutral. You cannot use the vacuum or even roll it into another room until the D is depressed. I believe Neutral is for bag and filter changes, repairs, etc. My thought is that it is designed that way so you can vacuum stairs without having it roll off the step......
So, if you run into the problem sometime that it won't roll, be sure the D is pressed.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 04, 2011 | Kirby G5 Bagged Upright Vacuum
My G7D kirby vac was accidently dropped and the D & N lever came out of the machine. When I put the lever back in the hole it belongs in it is very loose and it doesn't switch from D or N.
The drive/ neutral pedal assembly must be replaced. This part is pressed together and cannot be repaired. A new assembly is about $17-$20. The power drive unit must be removed from the machine.
Jan 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kirby g5d will not shift into drive
check tech drive sensor, where handle connects to main unit, but you need to open cover off and greese handle slider.
May 08, 2010 | Kirby G5 Bagged Upright Vacuum
THE NEUTRAL/DRIVE LEVER HAS COME AWAY FROM THE HOOVER AND SOME OF THE INSIDES HAVE ALSO COME AWAY. I WOULD LIKE TO KNOW HOW TO PUT IT ALL BACK TOGETHER
I dismantled the cover, withdrew the gear drive assembly and found the bits that had come loose. The mechanism that selects neutral or drive had come away from its shaft. I simply put it all back together and tightened everything back up. Works a dream again.
Jan 10, 2010 | Kirby Heritage II Vacuum
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G6 clicks while in neutral
Bracket cam assembly (see and buy HERE). It is worn so it does not disengage gears completely. On the part listing you will also find the instructions on how to replace it.
Rocky
Jul 29, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
578 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
