Question about Sony EVC100 Hi8 VCR
Controls on the unit work but cannot communicate with the remote. Have inserted fresh batteries in prop[er orientation. Any suggestions? Thanks. Ed Skurzynski skurzynski@q.com
  • skurzynski Mar 14, 2011
    Thanks. Setting Command Mode to [2] solved the problem. Switch was set to [4]. May have been set there by a friend who borrowed the unit several months ago. By the way, can you tell me what function the settings other than [2] have?
    Once again, thank you. No way would I have been able to solve this one.
    Ed
    Solved the problem perfectly.
    Thanks... Ed
    Top Expert:
  • Sony Master
  • 74,136 Answers
Hello
Just check the battery contacts of the remote commander for any dirt or rust. Clean the contacts well. The only thing that the manual of your device tells about the non fuctioning of remote control is about to change a switch. "Set the COMMAND MODE switch on the VCR to [2]. OK.
Posted on Mar 14, 2011
  • The Knight
    The Knight Mar 14, 2011
    Hello
    Feels very happy to know that your problem has been solved. If you wants the user manual of that device, send a mail to me a mail to me at or . it is an adobe acrobat document, and I'll send it to you by return mail. When you mail me, remind me the matter also, because I may sometimes did forget this. OK.
I forgot my code and whenever i insert battery on my remote the indicator is always on and therby my remote doesnt work
Press power or setup button if indicated light don't turn off make sure you have fresh battery could be a malfunctioning remote
Mar 08, 2016 | Televison & Video
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
Remote control will not communicate with RDR-HXD790
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get some details, check the site linked here. Pull up older posts. Details about how to check a remote control is given.
Dec 07, 2013 | Televison & Video
Remote controls bottons dont all work
Check its batteries first. Check with fresh batteries. Check the battery contacts at its battery compartment for any rust or dust accumulated. Clean them well before inserting new batteries and check. If it still do not work at all, you remote control must have some loose solder terminals inside its circuit board, or its infrared light emitting LED might be faulty. Clean the remote control before proceed. If you wish to get more details about how to clean a remote control, check this link. http://electronicshelponline.blogspot.com/ It has details. Pull up older posts.
Jun 14, 2013 | Televison & Video
Remote isn't working
Are the batteries fresh and making contact at each end? Are the batteries free to move inside the case? If they are too tight they may not be making proper contact. I imagine they are inserted the correct way round!
Mar 14, 2013 | Televison & Video
Remote control rmt b101a stopped working, changed batteries, same thing; did reset by pressing power, TV i/o and vol- simultaneously, still not working. Help!
Make sure that the Remote is operating in a range of 3 to 10 feet away from the unit.
Point the Remote directly towards the Remote Sensor of the Device.
Remove any obstacles that may be in the path of Remote and the Sensor.
Make sure that no interference is blocking the Remote to operate normally. Do not expose directly to Sunlight, bright florescent lights etc.
Try resetting the Remote by removing the batteries from the Remote control, press every button twice, and then re-install the batteries after 1 minute.
Make sure that none of the buttons on the Remote control is jammed.
Install fresh alkaline batteries in the Remote, do not use rechargeable batteries.
Make sure that the batteries are inserted by matching the polarity (+ & -).
Try resetting the Blu-ray Disc Player with which you're using the Remote.
If the issue persists, after all the possible troubleshooting steps, service may be required.
Thanks for using FixYa
Dec 03, 2010 | Sony RMT-B101A Remote Control
The up button on my dish remote is not working. I have to push real hard to get it to move upwards on the channels.
Assuming you have fresh batteries and nothing is blocking the remote from communicating with the IR eyes on the receiver than you need a new remote most likely.
Thanks for using Fix Ya.com.
Oct 16, 2010 | DISH Network IR Remote Control
Remote does not communicate with TV. Battery connector is loose.
Hi,if the remote was working perfectly before now with the TV,it means the problem is from the battery of the remote control,you have to replace the battery and ensure they are well inserted in the right positions. However,if you have done this and the problem remains,you have to unscrew the cover behind the remote and check the connection between the sensor and the panel,if the connection is broken you have to solder the sensor back to the panel.
Thanks and take care
Apr 21, 2010 | Sony RMT-V402B Remote Control
Remote for my hard drive recorder/dvd player won't operate
Went to the shop and bought some more batteries..... problem solved.Thanks for your interest. It's good to know you are there if I really have a problem!!!!
Jan 20, 2010 | Panasonic Televison & Video
Remote control does not work
Sounds like a bad IR sensor in either the remote or the unit.
Dec 29, 2008 | Audio Players & Recorders
Sony EVC100 Hi8 VCR Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
