I have replaced toner cartridge in HP laserjet 4 si. Now I have toner smears down the left side, about a 32nd inch in.
  • 1,591 Answers
I don't normally say "call the manufacturer" but if it's a genuine HP cartridge (not another brand, and not refilled) call 1-800-HP-Invent and they'll walk you through a few steps, and if the cartridge is defective they'll send you a new one.
The toners have an out of the box warranty, so if you took the toner out of the box 3 weeks ago, it's still under warranty.
Posted on Mar 11, 2011
HP CP2025 Heavy smears of magenta appear down the right-hand side of paper. Have tried restart and changing paper weight.
It is due to spilled magenta toner leaking from side to the toner cartridge. Take the cartridge out of the printer and clean it. Clean visible inside of the printer. Shake the cartridge lightly in horizontal position to evenly distribute the toner inside the cartridge and put it back. The issue sould be fixed after some prints.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 23, 2010 | HP Laserjet Cp2025n Printer
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
Hp 1505n laser jet, Makes clicking noises when printing. Slight smear on left side of page.
There are two things that can cause print quality problems and a noises. One being the toner cartridge and the other being the fuser assembly. If you have already replaced the toner cartridge and it did not take care of the problem then the fuser may need to be replaced. You can take it to a local printer repair shop to get it fixed.
Sep 16, 2010 | HP LaserJet P1505n Printer
HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
Apr 21, 2010 | HP LaserJet 2840 All-In-One Printer
HP laserjet P2015 is printing blank
Are you getting toner on the paper? To find out, print a test page. When you judge that the paper is under the toner cartridge, turn the printer off and look at the toner cartridge. Is your document displayed on the toner drum in toner? Is there toner on the paper?
No No Replace the toner cartridge. If that doesn't work you have more serious problems.
Yes No Replace the transfer roller.
Yes Yes If toner is smeared on the paper, replace the fuser.
Jan 08, 2010 | HP LaserJet P2015dn Printer
The right side of the printable portion of each doc prints light
You just need to remove the toner and reach in with a dry rag and wipe the little inch wide window that is above where the toner goes. This window gets covered with toner dust and makes prints lighter...It runs all the way from right to left above the toner and drum.
Nov 03, 2009 | HP LaserJet 4100tn Printer
HP LaserJet 2200 Series PCL huge dark smudge
Replace toner cartridge. If problem persist replace fuser unit. P/N # RG5-5559
Apr 28, 2009 | HP LaserJet 2200D Printer
Hp laserjet 3055 printer
black smear down page (either left or right) is caused by fuser. To check simply remove the toner cartridge, remove the 2 screws holding the fuser caution plate, gently pry the right side and look at fuser film for dammage. DO NOT FORCE the cover off the unit as it will break and then you'll need a fuser assy.
Aug 14, 2008 | HP LaserJet 3055 All-In-One Printer
Hp laserjet 2200d
If the toner smears after the page comes out of the printer you may need a new fuser. The fuser is the heating unit in the printer and can usually be seen from opening the back door. Check and see if it has a line worn down the same side as the mark on your pages.
Feb 15, 2008 | HP LaserJet 2200D Printer
189 people viewed this question
jasbo
jasbo
