Question about Magic (2004PROSONGPORTABLEKARAOK) Shelf System
Will a magic-jack hook to phone line that is spliced to all phones in your house work all phones.
  • Magic Master
  • 6,771 Answers
No! the device is designed to work through your computer only, it is not compatible with the rest of your phone system.
Posted on Mar 11, 2011
Why does a CS6124 not work with Magic Jack?
that phone should work with magicjack , you are not getting a dial tone because you are no setting it up right somewhere along the line ,
Dec 10, 2014 | VTech Communications Cs6124 Cordless Phone...
I moved. magic jack says no line when hooked back up
  • Is everything turned on?
  • Is the blue light, inside your Magic Jack dongle, on? (Note that the Magic Jack Plus should have a flashing red and green led as well.) If you use the older model you might need to connect it through a powered hub to ensure the device receives enough power to operate properly?
  • If this is a new installation, is your internet service and computer capable of handling the requirements placed upon them by Magic Jack?
  • Do all your connecting cables appear to be firmly attached?
  • Are you watching Netflix, downloading or streaming files at the same time you are attempting to place a call?
  • If you are using the Magic Jack Plus, does the system report Error 3002?
Next, you should ask yourself what recent changes you have made to the computer/Magic Jack software? What recent upgrades have you performed to your hardware? Could this have effected the performance of your Magic Jack?
If your difficulties persist, it is time to divide and conquer. Google a 'you tube' link and watch the video. If you cannot connect to the internet, consult your internet provider for assistance. If the video is choppy, the internet connection might be too slow or bogged down. Perhaps your computer is too slow or requires maintenance. If you cannot hear sound, you might be experiencing problems with your soundcard or sound drivers. You should check Control Panel/Sound and ensure that 'USB internet phone by Tigerjet' is installed.
If the video ran correctly, the next step would be to test your handset and phone cord at another location.
If you prove the handset/phone cord to be correct, you have pinpointed your fault to either the Magic Jack or its software. Contact online support for Magic Jack.
Oct 11, 2014 | magicJack Plus Pc To Phone Adapter
Magicjack phone
Have you tried a new telephone cables going to the magic jack? That would be the first place that I would start.
Can you hook up a telephone to the existing line that's plugged into the magic jack then see if the noise occurs. If yes, then replace the cable. If no, replace the magic jack module.
Jan 22, 2014 | Computers & Internet
Magicjack problems
Phone is not workin...not ringing on ether end goes straight toice mail...
Dec 09, 2013 | Android Apps
My home phone is dead when I pick it up and when I call in to it is busy? It lasted several hours then came back, now it is dead again. I disconnected all of the phones in the house and checked all of the...
Find where you line comes into the house. hook the phone up there if there is still a problem its not your phone or system. Call your phone company they have a problem in their line. If the phone does work OK then you will have to start isolating your extension jacks to find which one is shorted.
Nov 13, 2009 | Lands Phones
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
I have magic jack and am trying to use it for a medical device because I have a pacemaker and defibulater and it need to be monertered by a LATITUDE COMMUNICATOR.Can magic jack be used for the LATITUDE...
I have and use Magic Jack too..Does your Latitude Communicator just plug right into a phone jack with a regular phone cord? If it does, then it should work...You will have to always leave your laptop on and never turn it off because Magic Jack requires a constant connection...Plug your equipment into the back of your Magic Jack and then with another phone, call the company that monitors your pacemaker/defibulator and ask them to "test" your line to see if you will receive a signal from them through your Magic Jack...You will to have to plug it all in and then test or you won't ever know...When I plug my home phone into the back of my Magic Jack, I receive a dial tone just like it was connected to a home based landline phone
Jul 16, 2009 | Acer Computers & Internet
CAN'T GET FAX WORKING.
If it's answering on your main number, then you are not plugged into the fax jack. You should have a separate phone jack for fax. If you have internet phone there should be a second jack on the back of your phone box. You can test that you have a functioning second line by plugging the fax into it and using the fax unit to dial your home number.
Jan 05, 2009 | Dell 926 All-In-One InkJet Printer
Magic (2004PROSONGPORTABLEKARAOK) Shelf System Logo
210 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
