Question about Cobra Boating
Radio transmits at close distance only. - Cobra Boating
  • Ken Fowler
    Ken Fowler Mar 11, 2011
    have you checked the wiring and antenna for good connections?
  • 285 Answers
If the radio device has a variable strength setting for transmission, set it at the higher value... for example 5 watt as opposed to 1 watt. Also, ensure you have a quality antenna. Radio signals are usually line of sight signals, so if there are many obstructions between the radio antenna and the receiver/listener, strength of signal can be affected.
Posted on Mar 11, 2011
Bought a new cobra Every time mike is keyed it reads antenna warning Radio will transmit short distance and will on receive short distance Very short Cobra 29 L X B T LCD CB radio
The antenna warning is the key, the swr on the antenna/feedline is very high. check antenna connections, coax and connectors for damage
Apr 10, 2014 | Radio Communications
Loud squeal/feedback noise when transmitting from a Kenwood TK-3230 to a TK-3400U4p
If you're close enough to hear the receive on one radio while transmitting on the other, it's good old-fashioned feedback. Turn the volume down on the receiving radio.
Jul 11, 2013 | Radio Communications
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
I just purchased two radios. How far will they transmit and receive with good clarity in the city? I need to transmit and receive from about six to eight miles away clearly. Thanks.
bobengelman,
Typically and unmodified handheld CB will have a decent talk distance of 1-2 miles with both being a handheld. Further distances can be had if one of the radios was a mobile or base station with distances of more than five miles with weak signals. In some cases the antenna can be changed to a better longer antenna. Extention type antennas typically transmit about a mile per watt. Conditions such as terrain will have an impact on signal specifically mountains or buildings. Better results may also be had by purchasing a mobile magnet mount with a PL-259 to BNC to fit the radio. A magnet mount placed on a air conditioning unit or large cookiesheet as high as possible will make decent gains for distance if the radios are intended to be stationary.
JT Radiojunkie
Jun 21, 2010 | Midland 75-785 Handheld CB Radio
18 miles max range but actual it can transmit and
The reason for this is due to various possible conditions. The first being obstacles in the operation range of the unit. IE> hills buildings trees ect. This can greatly reduce the actual distance the unit will work in. The 18mile max is probably a rating that would apply in the best opt. scenario. You would have to be on a flat terrain with no hills or valleys,no trees or buildings for the unit to reach the max distance. In dense areas of trees,buildings or uneven terrian you wont even come close to these distances. Second: any unit RF unit that is held in your hand or close to your body does cause the antenna to detune to various degrees the amount that it does depends on how well the unit has been designed. The more it detunes the less resonated frequence is recieved and amplified making for a weaker signal. In conclusion for the best long range reception be clear of as much surronding interference as possible and as high a possible above any elevated terrian
Jan 17, 2010 | Motorola T8500 Two Way Radio
No distance on cb
Check your antenna. Make sure it is getting a proper ground. If mag mount; make sure base of antenna and where you put it are both super clean. Check where whip goes into coil or base. Make sure all allen screws are tight and whip is not either all the way down to the base or up to the top. If antenna is mounted; make sure that it has a good ground. You might have to remove some paint around the base to get a good connection. DO NOT TRANSMIT WITH A HIGH SWR. YOU CAN BURN OUT THE EXPENSIVE POWER OUTPUT TRANSISTOR. Hope it helps.
Tom
Jun 07, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Baby monoitor reciever piking up no sound or delayed sound - link light flashing
A delay may be caused by interference from other radio sources. I heard of one case where a woman's cell phone call overpowered the transmit power of her baby monitor.
Other things that can cause interference or other receiver problems:
1. monitor in contact or close proximity to running appliances or their cords. (induced electromagnetic field)
2. neighbor with baby monitor on same channel ('cross-talk')
3. distance between transmitter and receiver too far (the strength of a radio signal fall dramatically over larger distances. think of how often you lose cell phone coverage)
4. reduced power: low battery strength or cooked power supply
5. transmitter or receiver insulated from signal (if your monitor was transmitting/receiving through any metal obstruction)
May 07, 2009 | Kitchen Appliances - Others
Radio does not transmit
take your radios to a w/shop and let them check the final rfpower
Apr 02, 2009 | Radio Communications
MOTOROLA TALKABOUT T5400
First check your batteries. Try the battery pack from a known good radio. If you do not have a battery problem, your issue is probably non-reversible. Sorry. This style radio is non-repairable. The repairable Talkabout units include the Distance, Distance DPS, the TA-7400 and TA-7200.
Jul 11, 2008 | Motorola Talkabout T5400 (14 Channels)...
Boating Logo
130 people viewed this question
Top Cobra Boating Experts
RFburns
Level 1 Expert
Electro Med Services...
Are you a Cobra Boating Expert? Answer questions, earn points and help others
