Question about Biostar P4SXQ Motherboard
Biostar P4SXQ has an Audio problems, everything checked including 2 jumpers on audi pins and enabled in Bios, Yellow exclamation in Device Manager, Error Code 10
    Genius:
  • 1,400 Answers
Hello
I would statr with uninstalling the audio drivers then reinstalling them.
Possible you may need to install the chipset drivers first.Then the audio drivers.
Posted on Mar 11, 2011
Hi! no sound?! WinXP Prof 2002, MB P4TGV, In Bios Audio Enabled, There all drivers in Device Manager, In Control Panel in Sounds and Audio devices everything faded and "No audio device".
I know this isn't your exact motherboard, but this may help you in some way. Just to make sure the jumpers are set up correctly for the front panel audio. Click HERE and go to page 11 to see the jumper settings. You can also try to do a "Scan for hardware changes" in Device Manager. From what you have written, it seems to me that it's something to do with the audio in the bios, yet you say it's enabled. If this is a problem after installing a new program or operating system, it could be that the new software is to blame.
I hope this helps. let me know if there is anything I can do to help you further
Joe
Sep 02, 2011 | Biostar P4TGV-R (U8668DCOMB7) Motherboard
I got problem to input sound on g31 motherboared, please guide me how can i input sound in g31 motherboard>
The G31-M7 TE MB has a intergrated sound chip.
Enter the bios. Open Chipset. Open South Bridge configuration. Find Audio controller. This should be set to [Azalia] Save and exit the bios.
Next check JAUDIOF1: found on page 14. If you are not going to use the cases front audio and mic than there should be a two pin jumper covering pins
5 & 6 and pins 9 & 10. If you're case supports front audio / mic ports, (You can not use the front audio ports and the rear audio ports at the same). time). Once everything above is set, got to Biostar and download the audio driver software;
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
If you still have a problem with you're sound. Explain any actions you have taken.
Mike
Jun 06, 2010 | Biostar G31-M7 TE Motherboard
I recently formatted my computer and am trying to reinstall the drivers, I have them all except now I notice that my sound device is missing from device manager. There is none listed, all the solutions I...
First off, yes, the D915 series of boards all have Audio on board, with Line In (Blue Conn.), Speaker Out (Green Conn.), and Mic (Red Conn.) on the back of the motherboard.
The product manual is available on the intel website:
http://www.intel.com/support/motherboards/desktop/d915gav/av_manual.htm
It states that it includes a 6-channel audio subsystem based on the Realtek AL860 audio codec. The manual will eventually take you to the Intel driver download page:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+915+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D915GAV
The key, I believe to your problem, is to make sure you have:
1. the latest BIOS
2. the latest INF installed
3. the driver set for the ALxxx chipset.
Make 100% sure that within your BIOS that the Audio portion of the board is enabled.
Also, on Page 45 of the manual it speaks of the Front Panel Header (10 pin header between PCI slot and PCIe 1x), and notes the following:
To restore back panel audio, follow these steps:
1. Turn off all peripheral devices connected to the computer. Turn off the computer and
disconnect the AC power cord.
2. Remove the cover.
3. Remove the front panel audio cable.
4. Install a jumper on pins 5-6 (rear R channel).
5. Install a jumper on pins 9-10 (rear L channel).
6. Replace the cover.
Hope this helps.
Jan 06, 2010 | Intel D915GAV Motherboard
Installed new sound drivers about 1 month ago and recently when i would start up my computer it says no audi drivers installed
Check that the audio device isn't disabled. Go to settings / control panel / system / hardware / device manager. Check for anything with a red cross, yellow exclamation, or question mark against it. Re-enable the audio device if disabled. If you have an exclamation or question mark against any of the devices, remove them and re-install.
* This is for XP. Procedures for other versions of windows will be similar.
Dec 11, 2009 | Acer Aspire One PC Notebook
Original motherboard sound drivers from MB disk don,t work.
Here is a link to the driver page for your board.
updates and see if this is
http://www.biostar-usa.com/app/en-us/mb/driver.php?S_ID=377
You could try downloading the driver from the site..Maybe there is a problem with the one on the disk. Also check the BIOS updates and see if this is a known issue. They may have a BIOS update to fix this issue. Before installing the driver/software I would remove the current audio software and remove the audio from the device manager and then re-boot the computer. Then install the downloaded software and see if that works.
Sep 08, 2009 | Biostar TA790GX Motherboard
I have an eee pc 900 series, and the camera is not being detected
To turn the camera on IS in the BIOS. It's not in a logical "camera" spot but it's in there. My camera on my Eee PC 1000H got turned off somehow (not by me or by a BIO upgrade) so I found it and fixed it. Look for it in the BIOS menu's. It's there.
Aug 08, 2009 | ASUS Eee PC 900 PC Notebook
Does it support intel & amd?
Hi aventae, the P4SXQ motherboard will only support Intel Pentium 4 or Intel Celeron processors 400MHz CPU's.
Biostar's link for the P4SXQ MB.
http://www.biostar-usa.com/mbdetails.asp?model=P4SXQ
Mike
Jul 28, 2008 | Biostar P4SXQ Motherboard
Audio Driver issues
Right click my computer icon, click properties, select hardware then click device manager, check the audio device you can see the yellow question mark,insert mother cd driver then right click the yellow question mark and update the driver. otherwise change the audio driver..
Jul 02, 2008 | Intel DG31PR Motherboard
Asus a7s333 motherboard SiS745: onboard audio device not detected
1.) Check Device Manager for any "unknown" drivers, marked with a yellow exclamation point. If you find one that doesn't seem to belong to any of your other devices- you have your onboard. however, you may need to install the drivers for it.
2.) Check your BIOS. Some onboard cards have the ability to be enabled/disabled there.
Other than that, you could be looking at a dead card. All I can suggest if that's the case, to buy a new PCI soundcard to replace it.
May 29, 2008 | ASUS A7S333 Motherboard
Biostar P4SXQ Motherboard Logo
78 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
