Question about Sony STR-DH800
My str-dh800 develops an internal hum after being tuned on for a couple of hours
  • Sony Master
  • 6,771 Answers
The main power supply filter capacitor is the problem, as the temperature rises the capacitance drops while in use and eventually the audio gets a distinctive 60 cylce audio hum. The part must be replaced in order to correct the issue.
Posted on Mar 11, 2011
Testimonial: "thank you"
  • 3 more comments
  • John Cunningham Mar 11, 2011
    Thank you Jimmy! I'am glad I could help, John.
  • beamteam935 Mar 23, 2011
    I am experiencing the exact same problem, only the hum starts after about 5 minutes from when the reciever is turned on. I can't afford to replace it and having someone fix it is almost the same money. Where inside do I find this main power supply capacitor? Can I just buy the part from Radio Shack and swap it out? I have nothing to lose. I can't watch TV because all my equipment runs through it. Any suggestions? It is only 13 months old. Thanks.
  • John Cunningham Mar 23, 2011
    For a unit that is 13 months old would be unlikely but possible, first check your connections to be sure it is not one of the cords going to the other devices and dis-connect each item one by one to rule them out. Next! remove the top and the bottom pan to inspect the printed circuit board for bad connections, re-touch any that look poor. There are usually one to two main filter capacitors right next to the power transformer that will need to be checked, swapping out capacitors must be done carefully and observe the polarity. I don't know if Radio Shack would sell the type of filters you are looking for, check before you remove anything and good luck.
  • daniel strzelecki Apr 18, 2011
    hi,
    I have this problem but the hum sounds like it is coming from the tranformer itself, you can hear it even when volume is on 0 :-( only hapens when its warm. if it is the same fault i should be able to fix it. any help would be very very much apreciated (want to avoit replacing the whole big transformer)
    dstrzelecki
    18 minutes ago
    hi, I have this problem but the hum sounds like it is coming from the tranformer itself, you can hear it even when volume is on 0 :-( only hapens when its warm. if it is the same fault i should be able to fix it. any help would be very very much apreciated (want to avoit replacing the whole big transformer)
Sony dh800 transformer buzzes when warm, you can hear it on 0 volume and it sounds a little like the largest transformer. please help.
sony dh800 transformer buzzes when warm, you can hear it on 0 volume and it sounds a little like the largest transformer. please help. same problem as above
Apr 18, 2011 | Sony STR-DH800 7.1-Channel Audio Video...
After only 5 minutes of turning it on, My Sony STRDH800 emits a loud hum, then the word "protect" is displayed on the screen, then it shuts off. The hum is very loud and you can't turn it down...
Are you sure that's what it is? Something is heating up for sure.
It could be protecting itself because something in the volume control is going bad and sending too much current through the amp or any other reason. In other words, you can guess and buy parts hoping to nail the symptom but not knowing the cause, or you could let a technician do it.
Mar 23, 2011 | Sony STR-DH800
I have a Sony STR-DH800 which was purchased in May of this year. It was working fine until last weekend when the speakers popped and the unit said it was protecting and shut down. Now I can power on the...
Only solution go back for warranty if there is no answer for this solution in the user manual.
release power connector for a moment isnt the right thing tom do , this product is to young for any kind of problems, the hum is look like there is a capacitor damaged or something loose in the power supply that there failed a powerline , the only thing is back to the dealer for warranty.
Apr 23, 2017 | Sony STR-DH800
I can't get the speaker B option selected on my Sony STR DH800 7.1-Channel Audio Video Receiver
If you're using the terminals for Surround Back (7.1) there is no Speaker B option.
See the notes on page 19 of the manual.
Mar 03, 2010 | Sony STR-DH800 7.1-Channel Audio Video...
PROBLEM CONNECTION SONY STR-DH800 TO BOSE 901 PASSIVE EQUALIZER
on my sony STR-DH800 only center speaker is heard the side speakers is very very low
Feb 18, 2010 | Bose 901 EQ1915 Home Equalizer
Own a SONY 7.1 STR DH800 receiver, how do I fix protector message?
There could be a number of issues wrong with this unit. If you have removed all inputs and speaker outputs and the unit still goes into protect you could either have a problem with the switching power supply or a shorted output stage. Both would require a trained technician to troubleshoot and repair.
Feb 11, 2010 | Sony STR-DA5200ES Receiver
Subwoofer hum from STR-DH800
That points pretty much to a bad shield on the cable. Have you tried another one? Another thing to try is to rotate the AC power cord on the sub (if it has one). Sorry, too lazy to look it up.
Dec 29, 2009 | Sony STR-DH800
I have my 80 gb PS3 hooked up to my STR-DH800. I
You may need to enter the setup menu on the PS3 and enable the decoding for blu-ray discs.
Dec 13, 2009 | Sony STR-DH800
Sony STR-DH800 Logo
249 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
