How do you take a cover off a hard drive - Computers & Internet
    Sergeant:
    Champion:
  • 205 Answers
Remove the screws from the case there are usally four one on each side and then there will be Another screw underneath the manufacturers label. Feel around on the sticker for the head of the screw and sut around the screw head pull off sticker from top of head and remove the screw. Be carefull not to touch the discs inside the hard drive. The oild from you finger can render it unreadable.
Hope this helps.
Zeppelinx12
Posted on Mar 11, 2011
How to remove the cover
Try connecting the hard drive to another computer.
May 04, 2013 | Samsung M2 PORTABLE 320GB USB20 HARD DRIVE...
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
How to set a toshiba hard drive to slave?
Power off the Toshiba laptop. Remove the power cord and the battery.
Turn the laptop upside down and remove the panel where the hard drive goes with a screwdriver.
Depending on the model of Toshiba laptop being worked on, this may include the entire bottom panel, a panel covering both hard drive slots or a panel covering the empty second slave hard drive slot.
Install the second hard drive by inserting it into the open slot.
Replace the opened cover.
Replace the battery and power cord.
Turn on the computer.
The second hard drive is automatically configured as the slave drive.
Depending on the operating system and previous status of the slave hard drive, it may need to be partitioned or formatted before being used by the operating system.
hope this helps
Sep 13, 2012 | Toshiba Computers & Internet
How do i remove Hard Drive from my Acer Aspire Note Book Model 5742Z Taken one screw out of carrier for HARD drive still cannot remove drive &carrier help Ken Leatham
I found this online, so hopefully it helps. It's to a page selling a second hard drive caddy for the 3623WXCi, but at the bottom is has directions on replacing the hard drive for that model as well.
http://www.batterystyle.com/acer-aspire-3623wxci-caddy-p-413622.html
Sep 06, 2011 | Acer Aspire 3623WXCi Notebook
My seagate external hard drive cable cannot be connected to the external hard drive. the mechanism to hold the cable has loosen and is now inside the hard drive. What can I do?
You can unplug all wires from it.
Remove the screws which hold the chassis (cover) and remove the cover to access the hard drive inside.
Once the cover is off, you can see the connector inside and repair it back the way it was.
Replace the cover and screws and you are done.
Apr 15, 2011 | Seagate Computers & Internet
I need to replace the optical drive in a compaq presario c300nr laptop. How do I get to the drive?
Hi.
The hard drive cover is located at the base of the computer. To replace the hard drive:
1. Prepare the computer for disassembly, turn it off, disconnect power adapter and remove main battery.
2. Loosen the two Phillips PM2.5×5.0 captive screws that secure the hard drive cover to the computer.(see pic.1)
3. Lift the rear edge of the hard drive cover , and then swing it up and forward and remove it.
4. Slide the hard drive to the right, and then lift the hard drive from the hard drive bay.(pic 2)
5. Do operations in reverse order to install the new hard drive.
Pic1:
Pic 2
Regards.
Ginko.
Nov 17, 2010 | Computers & Internet
How do i remove my hard drive on my ps3 unit?
If it is an older type PS3 (Phat) on the left hand side of the console there is a small plastic cover. Using a small flat blade screwdriver, carefully prise one end of the cover outwards. There is a small cut-out on one end where the screwdriver goes. When you have this cover removed you will see a blue cross head screw. Remove this screw. You will also see a small wire clip that is attached to the side of the hard drive caddy. Pull this clip outwards. Carefully take hold of the clip and slide the hard drive towards the front of the console. The hard drive will then come out of the side of the console.
If you have a PS3 Slim the procedure is slightly different. On the bottom of the console there is a small flip out cover. Carefully remove this cover and there will be a blue cross head screw. Remove the screw. Now look below the slot where you put your discs. There is another plastic cover. Slide this to the right and remove it. Behind that cover is your hard drive. Flip the metal clip down and pull the hard drive out.
Hope this helps!
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
1 Solution for "dell inspiron 8600 laptop how
The hard drive is behind the cover where the mic and earphone are located. Turn the laptop over and there is a single screw that secures this cover. Remove the screw then slide the cover and hard drive out. The cover and cradle are attached to the hard drive.
May 08, 2009 | Dell Computers & Internet
Hard drive removal
Remove the hard drive
  1. Loosen the two Phillips-head screws that secure the hard drive cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the inside edge of the hard drive cover and remove it.
  3. Loosen the spring-loaded Phillips-head screw that secures the hard drive.
  4. Hold the Mylar tab and pull the hard drive toward the outside edge of the base enclosure to disconnect the hard drive from the system board connector.
  5. Lift the hard drive out of the bay and remove.
  6. Place the hard drive in a static dissipative bag.
Replace the hard drive
  1. Remove the hard drive from the static dissipative bag.
  2. Place the hard drive into the hard drive bay.
  3. Push the hard drive toward the inside of the base enclosure until the connector is seated.
  4. Tighten the spring-loaded Phillips-head screw that secures the hard drive.
  5. Insert the hard drive cover into the enclosure.
  6. Tighten the two Phillips-head screws.
Nov 16, 2007 | HP Pavilion Ze4805us Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
