Question about Gateway GT5428 PC Desktop
My computer won't start. It run the start up fan on high and doesn't get past that point. It will run there forever and not start.
  • 36 Answers
Maybe you should open the casing to clean it up to prevent
the air circular blocked.
Fan spin high is kinda build in protection of overheating of CPU.
Posted on Mar 11, 2011
About my dell desktop?
If it gets hot, fan will speed up. If it's getting hot, possibly the silicone grease between the heat sink and the CPU is dried up, or else you have poor contact. (Loose snap-down hardware)
Fix it soon, or Bye bye CPU.
Nov 05, 2014 | Computers & Internet
Cpu fan running at full speed
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
desktop or laptop computer fail to boot for a variety of reasons, but a fast, loud fan noise signifies that the system is suffering from overheating.
The problem, and the steps for troubleshooting it, is not unique to the Gateway Desktops.
When the internal temperature of the computer reaches too high a level, the system will shut down automatically to allow the heat to dissipate.
If you attempt to power up too soon, the machine will not boot properly.
To boot, you will need to correct the cause of the overheating, and keep the machine cool.
Blocked Vents
Although different in size, both desktop and laptop computers have air vents to help the fans keep air circulating around the hot internal components.
If these vents become blocked, by pushing a desktop too near a wall or using the laptop on a soft surface, the air supply your internal fans need to cool the system is cut off.
This blockage also traps the heat inside, allowing it to build to dangerous levels.
Keep the air vents on your computer free and clear to allow proper airflow.
Dirty Computer
Airborne particles, such as dust, lint and hair, can gather on the air vents and internal components over the course of time.
This accumulation of dirt not only provides a sort of "insulation" to the electronic components, preventing the heat they generate from dissipating normally, but it also clogs the fan and heat sink to prevent proper function.
Use canned air and damp, soft cloths to thoroughly remove any built-up debris from inside your computer.
Dried Thermal Paste
The heat sink sits atop the CPU chip to help dissipate the heat the component produces. Thermal paste is layered between the CPU and the heat sink to help draw the heat away from the chip for cooling.
Over time, the cooling properties of this paste decreases, and the substance becomes dry and flaky.
You can replace this paste to renew its cooling assistance by removing the old paste remnants with rubbing alcohol and adding a new layer.
Thermal paste is also known as thermal compound or thermal grease, and is available at most electronics stores.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Hot Environment
When examining overheating causes, don't overlook the environment you use your computer in.
External heat sources, such as fireplaces or even rays of direct sunlight, can cause the internal temperatures of your computer to rise.
This causes your internal fan to run harder in an attempt to dissipate the combined heat before temperatures rise too high.
Move your computer away from external heat sources to encourage more effective cooling.
Hope this helps.
Nov 28, 2012 | Gateway Computers & Internet
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
Dell 4100mp fan won't turn off
I reckon ya got a busted thermostat and that'll probably cost more to fix than the unit is worth so you may have to just unplug it from the socket when yer finished using it. Thats my only suggestion, sorry l could'nt be more help..
Dec 04, 2017 | Dell 4100MP Multimedia Projector
How do i put more antifreeze on my hhr
How long does it run after shut off?Does it shut off at all or just run forever? If it ends up shuting off at some point after shut off, then I wouldnt worry to much bout it. The fan will run until the temperature sensor tells the computer that your engine is cool enough whether car is off or not. If it never shuts off then that'd be different : ) can honestly say I haven't seen that b4 but I'd say start at the temp sensor chk for voltage readings and see if they are within specs for your vehicle. Maybe sending constant signal to computer. Hope this helps you out.
Jun 28, 2012 | 2006 Chevrolet HHR
1995 318i ac fan won't come on
You will probably need to replace the resistor behind the dash. Usually the first symptom is the fan will only blow on high but not on the lower speeds. If that is the case, then the resistor ( cheap fix) is the culprit.
If you just lost it all of a sudden, you should check for a bad fuse and will probably find other things that don't work too. Replace the fuse and watch to see that it doesn't go out again - which if it does, you have a short somewhere that needs to be fixed.
Aug 06, 2011 | 1996 BMW 318
1994 camry won't start after cleaning under the hood check dist. cap replaced spark plugs sounds like its going to start then doesn't.
Sounds like wet or moist spark plug wires. If this also occurs during early morning high dew point humid air, then you may have spark plug wires shorting out.
Replace wires.
Jul 02, 2011 | 1994 Toyota Camry
My GE Microwave Oven won't let me change the Power Level. It is on 10 and takes forever to warm up food. It is supposed to default to Hi but doesn't. I followed the directions for changing the...
There is a solid state switching device called a triac "electronic voltage controller" that has malfunctioned, it controls the power level settings when making power selection, It will need to be replaced to correct the problem. This repair should be done by a qualified technician because dangerous high voltages are present.
Jun 07, 2011 | Microwave Ovens
My tower turns on and makes this consistent beeping sound. And nothing shows on the screen.
I believe from my own past that the beeping sound is an over-heating alarm, and that you need to get more fans installed inside. Try taking off the door to your tower, and point a fan in on it and turn off the computer, wait about 5 minutes with the fan set to high to see if that solves your problem. If it doesn't then I suggest you take it in to the shop or wait for some more possible answers on here.
Hope this helps!
Remember to give me 4 Thumbs Up for Helping out the Community :)
~~Dayminner
Jun 03, 2011 | Computers & Internet
High speed fan
the thermo switch determine how high and how long the fan need to run to obtain the proper temperature, it will be a consern if the fan doesn't run.
as far as the upgrade of your machine. do you have enough RAM (2GB minimum) and how is the CPU?(1.6GHz or better) can the CPU handle the operating system. Since you didn't mention that, and by reading what you say, I believe the machine is not able to handle the Vista, that is why the fan is running at high speed and non-stop. The CPU is getting hot, and the power supply is pulling lots power.
Vista loading takes approximately 1-2 minutes, dependent on how many applications you have installed and what you have on the desktop.
roll back to XP from Vista is no possible, the only way is to reformat and reinstall XP.
Dec 01, 2008 | Computers & Internet
Gateway GT5428 PC Desktop Logo
163 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
