Question about Belkin F5D8011 Wireless N1 Notebook Card Network adapter (884667309300901)
Installed my Belkin card and connect to my Netgear wirless router everthing went fine but.. won't turn on without being connected to electric.
    President:
  • 1,623 Answers
Click start right click on computer or my computer then click manage . click on device manager in the top right window a list of devices will open in the top right window goto network controllers and click the + to the left of network controllers right click on your belkin card and click properties.click on power management and where it says allow the computer to turn off this device untick it
Posted on Mar 11, 2011
Belkin wireless G router incompatible with netgear modem
connect your computer to netgear modem alone and check for the ip address in the computer
(make sure that you have selected "assign ip automatically" in computer)...
to open command prompt type "cmd" and hit enter in run box...
then you can check ip address by typing "ipconfig" in command prompt...
make a note of IP adress or ipV4 address found under the heading "ethernet adapter local area connection"
it might be 192.168.X.X
now connect only the belkinrouter and check for the ip address using the same steps above...
it might be 192.168.2.X
make a note of that...
now compare both the ip addresses if they both have the same value in first three places...that is
192.168.2.... or something like 192.168.1.... or 192.168.0.... then you are facing with double NAT issue...
all that you need to do for that is to change the ip address of belkin router...
if it is 192.168.2.1 change into something like 192.168.15.1...the issue will get resolved....if not you can reset the belkin
router by pressing and holding the reset button for 30 seconds using a toothpick when the power is turned on...
Apr 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
Drops the internet connection and has to be rebooted at least once a day.
Try to reduce the MTU of the router. If you're on DSL, set the MTU size to 1492, for Cable connection size is 1400 or 1463. You can do it on the router's admin page http://192.168.1.1
May 11, 2009 | Belkin (F5D7230-4) Router (587009)
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Problems connecting to belkin
Connect directly to the modem with a Cat5 cable, and first ,see if you can get online. Then if you can, connect the router to the cable modem.Then connect directly to the router. see if you can get online through the router while being connected with the Cat5 cable.
If you cannot get online this way, we have to see if the problem is the router or the cable modem.
If you can get online while you are directly connecter, you may need to re-install the drivers for the USB Netgear device.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Notebook card and its wireless access point
In Ideal scenarios, you should just plug in the card in the notebook and it should get installed automatically.
Thanyou may scan for the available networks and you should be able to seethe network of your Netgear router(Assuming that the Netgear you havementioned is wireless capable and configured).
You can connect to the network and it should work fine.
Check this link
Let me know what happens.
Regards,
Sammy
Jul 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Looses connection
upgrade the firmware or buy new wirless n u love it linksys only netgear are terrible in games
Jan 31, 2008 | NetGear WGR614 Wireless Router
Pc works via ethernet cable but wireless laptop cannot see the network
I think you have lost your PPPOE internet connection. Reestablish the connection. If this is not the problem, click your wireless connection on the taskbar and search for your wireless device and reconnect. BPCS
Dec 29, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connection problems
If Internet sharing is set up correctly one pc will be the one that connects directly to internet, the other will connect through a gateway or other device connected to your network. Check they have'nt both got the same IP address. Is this related to last problem, did you get the wireless card working wirelessly online?
Nov 20, 2006 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Belkin F5D8011 Wireless N1 Notebook Card  Network adapter (884667309300901) Logo
51 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
