Question about Nikon COOLPIX P90 Digital Camera
After my kids dropped camera on carpet (it was on but lens was not out, they were viewing pictures). The lens will not move, it's stuck and makes grinding noise like it wants to move in and out. After it tries this for 4-5 seconds message appears: "lens error, if lens cap is attached, turn the camera off remove lens cap and turn camera on" Obviously lens cap is not on but camera reads it as such. THANKS!!!!!
    Champion:
  • 226 Answers
Hi dear alexanderesma, your lens have the pin roller's out of cylinder helicoid,some case maybe repaired, otherwise change of lens unit become necessary.
Please send to Nikon service.
Regards
Posted on Mar 11, 2011
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
I own a casio exilim ex-z850. it has been showing a lens error, every time i try to take switch it on. the memory card is fine, i view the pictures. but the lens wont open up or anything. please reply...
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Sep 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Canon Powershot a610 dropped, lens stuck half way, won't move, gives E18 whenever one puts it in the mode to take a picture, no view through lens. Is the camera toast?
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Nov 19, 2009 | Canon PowerShot A610 Digital Camera
The lens opens and makes a ticking sound but light stay orange
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Jul 15, 2009 | Olympus FE-210 Digital Camera
Dropped my camera.
Hello there,
Jul 22, 2008 | Canon PowerShot A85 Digital Camera
Dropped my camera lens seems to be stuck
Contact Nikon USA (if you're in the US) and ship them the camera and attached lens.This will cost, which they will estimate up-front, but it is the absolutely best solution to the problem. Anything else is a hack job!
Jun 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Dropped camera and lens Dstuck , sony cyber shot DSC-W50
There are 3 pins in the camera lens that slide in grooves allowing it to move you have knocked out 1 or more.
only an experienced tech can attempt fix , camera must be totally disassembled.
Jan 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
'Turn camera off and turn back on' message
TRY DROPPING THE CAMERA -- YOU HAVE NOTHING TO LOSE!
I was heartbroken to learn that my Lumix DMC-TZ1, which I purchased 2-3 years ago, had died -- right during my daughter's dance recital, for seemingly no reason. Tonight I was surfing the web researching replacement cameras (many brands), and I realize that I feel like there is no real "history" on the camera that's any worse than any other camera on the market, including the Canon Powershots, which are all the rage right now. So I started researching on the Fixit site other cameras for possible problems.
What I found is that all the cameras have funky messages (Sony and Canon included!) that result when he camera has been dropped or the lense has somehow been altered. So I read all the different "solutions" and then came up with my own:
I decided that the lense needed to be un-jammed. At this point, if the camera was useless to me, I might as well take a chance and try to unjam it. So I did!
I held the camera about 3-4 inches from a table top. Then I simulated a "drop" (without the case) that was gentle enough that it wouldn't smash the LCD but that would maybe make the lense unjam. (Note: I couldn't SEE any problem with the lense; this was just a hypothesis I couldn't go wrong trying.)
Each time I put the camera on, tried to modify the zoom (a function which normally makes me get the error message forcing me to turn the camera off), and then got the message. BUT the 3rd or 4th time: TA DAH! NO MESSAGE! INSTEAD, A SHOCKER: I WAS ABLE TO MODIFY THE ZOOM! AND THEN I TOOK A PICTURE! AND VIDEO!!!!
So my camera is back! And I also have discovered that the flash problem I had started to have previously has now seemed to have gone away also.
My advice is to just TRY! You have nothing to lose: try "dropping it" back into shape! I know it sounds crazy -- but I just saved at least $200 by doing this!
Mama Maria in Burke VA
Sep 17, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Sony DSC-W80
Ok, this is to all of you who had or will experience the same problem that I had as well. I found the simple solution that SONY should have tell us, but ... Never shake it!!!
Now get ready, is easy fast and reliable. Get WD40, a needle, a glass, tissue paper, a thin screw driver and a clean table. Now as you were to take a picture, at the left side of the camera you will find a pice were is written 3x optical zoom you will find a screw. Open ONLY this one and carefully remove the cap. Now, at the bottom, you will see a small black block with a **** with a tiny metal part in it. Ok, you are set to repare your camera. Lay the camera optic upward. Now use your glass to extract the WD40 with no mess, you just need a drop of it (well away from your camera)! Now dip the needle in the drop and apply the liquid on the tiny metal part in the ****. Repeat this once only just to make sure you have put enough lubricant. Now swich ON and OFF several time the camera until full recovery of the lent function. This work perfectly well and if you feel confident, add a drop on the elicoidal plastic groove, but no mess and clean any remain on the plastic as oil is going to run over time. Two half drop on the out lent caps could help as well. close the lid and your set for good years runing! Good luck. David
Aug 20, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Jul 28, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Nikon COOLPIX P90 Digital Camera Logo
388 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
