Question about KitchenAid ProLine 600 Stand Mixer
The mixer, Professional 550 HD, makes a prominent grinding sound every time we run it. We have not tried to repair it.
ricardok45
  • 135 Answers
SOURCE: Kitchenaid mixer makes a clanging noise
Hi. If your mixer is under warranty, call Kitchenaid. They are very good at replacing mixers under warranty.
If you are out of warranty, this is where the fun begins, NOT!
Remove the silver band from around the top of mixer. Remove 4 screws that secure the top cover, remove cover and at the front top of the machine locate the transmission cover. Inspect this cover carefully for cracks. If you find cracks in it...You have just discovered Kitchenaid's dirty little secret. A cheap plastic transmission housing! The failure of this cheap part is the cause of all of the rest of the damage inside the mixer, which may include a destroyed worm gear and shaft, destroyed bearings and their seats. You're not alone. I estimate that thousands of these plastic parts have failed causing great damage to the rest of the mixer
Kitchenaid's replacement housing is made out of metal. If you feel up to the task of repairing the mixer yourself goto the Kitchenaid website and do a search for the parts catalog for your mixer model, these will assist you with disassembly, reassembly and parts ordering.
If you're not up to the task, take it to an authorized repair place once you have put the cover back on.
Even if you're out of warranty, you may be able to have Kitchenaid pay for the replacement parts, they did for my mixer. Be persistent with them and try to get to a manager with your complaint. This cheap piece of plastic has no business being installed on a high-priced machine.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
  • 118 Answers
SOURCE: kitchenaid professional....
It sounds like you need to change the brushes. You can look up your parts manual online here and then buy them online. Should be under $10.
Posted on Nov 30, 2008
ricardok45
  • 135 Answers
SOURCE: Thumping Noise Under Duress
Hi. Your problem probably lies in the plastic transmission housing. This cheap piece of plastic has no business in a high priced mixer, as it has two important shafts that depend on the integrity of this housing for their bearing seats
Remove the top cover from the mixer. At the front top of the mixer is the trans. housing. Examine this housing carefully for cracks. If you find cracks, then you have new damage inside the mixer. If, when you replaced the three gears, I suspect that you did not discover the cracks in the trans. housing and reinstalled it after you replaced the gears, or you may have missed internal damage from the first breakdown.
When this cheap plastic part fails, it can destroy the worm gear, it's bearings and the bearing seats and possibly more.
Kitchenaid's replacement housing is made of metal. Kitchenaid markets these mixers saying it can handle bread dough. The ugly truth is they cannot!
You must open the unit up, remove and save the grease if it's relatively new. You must check every moving part in the mixer's transmission. You have to remove grease from these parts in order to find the damage. When you have the unit repaired, sell it!
I had the same problem with my mixer. I replaced all of the broken parts, and sold it. Since then, I bought a used Hobart N50 ( 5 quart), and an A200 (20 quart) mixers, both of which are commercial mixers. Both of these can handle heavy dough and they do so with ease.
Kitchenaid, to this date, have refused to recall these trans. housings, even though thousands of these cheap plastic housings have failed. Good luck with this saga!
Posted on Mar 31, 2009
  • 143 Answers
SOURCE: grinding sounds and slower mixer speeds
It sounds like you may have a broken worm gear inside your mixer which is a common problem.It is a wearable part which transfers the power from the motor to the main drive. It may be chipped or damaged right now, and running it will cause more damage. Part number for the worm gear is W10112253. This does however require some know how to replace. Hope this helps
Thanks
Posted on Nov 22, 2009
hslincoln
  • 235 Answers
SOURCE: Mixer infected by foul demons makes bad noises
Hi, JSTEWART431, are you sure it’s the motor or could it be the transmission gears where the noise is coming from? Are you sure it's the motor or could it be the transmission?
It 'sounds' like you've got some transmission gear issues. It could be as simple as through normal use the gears have shifted slightly in the transmission and the gear teeth are making different contact, hence the grinding noise. The higher the speed, the louder, higher pitched sound you'll get. Alas, the noise may also be indicative of a potential gear failure, similar to my wife’s mixer where the mixer’s increasing noisiness finally ended with a broken tooth on the bevel gear and the mixer 'froze'.
If you are DITY type person, feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM90P, and select the first file listed under Parts List (16) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled: Case, Gearing And Planetary Unit for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 36, Worm Gear Bracket & Gear, including Illus. No. 7, Worm Gear. I suspect this is the weak link in your mixer’s transmission and causing the problems. After clearing all the grease away, check to see if the gear is just loose, exceedingly worn or broken. If it’s worn or broken you can order a replacement part and install it yourself. While you’ve got your mixer this far apart you can check for any other unseemly wear and tear on the on the gears and other components. Besides a replacement gear, and grease you might consider replacing the gasket, too. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
The next possibility to check would be with the motor itself, but electric motors are pretty simple mechanisms and generally don't fail. Using the parts list, you can see what needs to be inspected and determine if any motor parts need replacement. (Generally only brushes wear out, but I don’t think that would cause your grinding sound.)
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here’s a link to an excellent site for disassembling/fixing your KA Mixer: http://www.neilcrockett.com/mixer.htm and another link to a site that details the disassembly and replacement of mixer’s grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 05, 2009
Testimonial: "Haven't gotten to attempting a fix on the mixer yet, but this reply has been very informational and will certainly be helpful. It is much appreciated!"
Where are the so called brushes on a HD professional mixer
brushes are the carbon blocks that run on the commutator to complete the electrical circuit to make the motor work
If you need to access them then best take it in to an appliance repair shop for a service
Jun 25, 2016 | Food Mixers
How do I fix a kitchen aid mixer that possibly shorted out?
Buy a new one quick. Or hide. Spent . electrical engineering. And supply of new diodes resistors and capacitors are needed.
Apr 17, 2016 | KitchenAid New Professional 5.5 QT...
KitchenAid mixer,model # KG25H0XMC5 will not turn on.
Check different outlet. Make sure the outlet isn't at fault.
Aug 01, 2014 | KitchenAid New Professional 5.5 QT...
When raised to do whipping my professional 550 hd mixer attachment does not scrap the bowl to mix properly
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
Kitchen Aid 550 Pro Mixer New Worm Gear and Worm Gear Follower Issue
It would be helpful to get the model number and serial number off of the bottom of the mixer. This will help determine if the gearing has changed at all.
Usually when a mixer is making a lot of noise after replacing the gears we can find a small nick or gouge in the gear. even the smallest damage can cause these mixers to make a lot of noise. Also if you have an older mixer there was a change in the worm gear from 53 teeth to 60 teeth on the gear. If your mixer originally took a 53 tooth gear, and you replaced it with the 60 tooth gear it will make a lot of noise like you are describing.
So first check your serial number, if the first 4 digits are after WL45 your mixer would have a 60 tooth gear, however if it is a WL44 or before you would have originally had a 53 tooth gear and this is what is causing the loud noise.
If your mixer is new enough that it took the 60 tooth gear, then take the mixer apart, clean and remove all gears, clean them off with wd-40 and inspect closely, even the smallest chip can cause a ton of noise.
If you have any questions, or you cannot find the problem feel free to contact us at The Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
We Repair Anything Under the Moon!
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
The motor is making a grinding noise. The mixer still works, it just sounds weird.
I have fixed many mixers with the same problem. The only part that consistently wears out
is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out
and becoming chipped. The grinding noises you hear are made by the Worm Gear and the
Follower. As time goes on, the metal filings from the damaged follower will eventually destroy the Follower and the Planetary will stop rotating.
Sooner or later that gear need to be replaced. Also remember to use new Grease after
a new gear replacement (metal filings from the old gear will damage your new gear)
Apr 02, 2011 | KitchenAid KP2671 Professional 6 Series...
My Kitchen Aid KSM150PS Artisan red mixer trembles alot and makes a grinding sound when I use it. I've exchanged it once already and have the same problem again.
Kitchenaid mixer are supposed to make a slight grinding sound while operating under load. This is simply the gears meshing together while the motor is turning them, but if the sounds gets worse or is already a metal grind type sound this could indicate a broken worm gear inside the unit, and shouldn't be run any longer. However if your mixer isnt on SOLID ground this could cause the tremble as well.Hope this helps
Thanks
Oct 31, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid ProLine 600 Stand Mixer Logo
463 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
