Question about Kodak EasyShare CX7430 Digital Camera
Kodak Easyshare CX7430 losses memory when shut off
When I turn the camera to auto from off it reads { memory card requires formatting } and offers two choices {continue or cancel}: cancel shows the message { memory card cannot be read format or try another card } of which I did both, and "continue" shows an hourglass that reads { formatting } which allows pictures to be taken, only to get the same problem when I turn it back on, except then it never stops formatting, even if I shut it off! The camera worked fine until I asked someone to take a picture for me, it's been this ever since, tried new batteries, new memory card, full charge, and notta - please help!
  • Anonymous Aug 10, 2008
    I have the same camera and the same problem. Can't use SD cards anymore, only the obsolete Multimedia Cards that are extremedly hard to find on shops because SD cards are the substitute for them... hope you can find a Multimedia Card. At least mine works fine with them.
  • Anonymous Mar 23, 2014
    Do I recharge putting in new battery? Did, still would not turn on. date screen stays on until I remove battery. Will NOT turn camera on.
I had this same problem. I couldn't get my camera to take anymore pictures while using my SD cards. So alls I did was took my cards to walmart, put all my pictures on a cd and then inserted my card again, when it brought up formating I okayed it to delete all the pictures since I already got them put on a disc. Once I did this is worked fine. Your cards can only hold so much depending on the size of your card and if you have to much on it your camera will not read it. Hope this helps you.
Posted on Nov 30, 2008
Posted on Aug 10, 2008
Hi There, I have unintentionally 'formatted' a
well ask Kodak. they have help there.
all cameras work diffr. you need to work with them.
ive never seen any camera that allows the OS, to be erased.
wow.
but i have seen cameras with one memory,
it will lock up if the memory is not reformatted,
RTM read the manual , under how to format the memory.
then do that. and turn off cam.
take out the batteries, for 1 or 2 mins. put them back.
now see if it turns. on.
if you can get the menus back use the factory reset mode.
Oct 02, 2013 | Kodak EasyShare CX7430 Digital Camera
How to switch from internal memory to external memory card on Kodak CX7430
Insert a compatible memory card. The Kodak CX7430 works with MMC and SD cards, 2GB or smaller.
Apr 19, 2013 | Kodak EasyShare CX7430 Digital Camera
Formatting sd card 8gb for kodak cx7430
The CX7430 uses SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work with this camera. You need to use SD cards, 2GB and smaller.
Jun 15, 2012 | Kodak EasyShare CX7430 Digital Camera
Can i format a 2gig section of my memory card only??maybe split it into two x two ??
Not for use with the CX7430. SDHC cards are electronically incompatible with SD devices. Even if you partitioned an SDHC card, the camera will not read it.
Jan 14, 2011 | Kodak EasyShare CX7430 Digital Camera
Need to format my 4GB sdhc memory card to my Kodak easyshare cx7430....any ideas
I've tried a 4GB memory card in my Kodak CX7430 camera and it doesn't work. I've been able to use any size up to 2GB so I'd suggest going to a 2GB card.
Nov 27, 2010 | Kodak EasyShare CX7430 Digital Camera
Format sdhc card for Kodak EasyShare CX7430
According to the specs on the Kodak web site, the CX7430 uses SD cards, not SDHC cards. While SDHC cards will fit into SD devices, there are hardware differences that keep them from working. You need to use SD cards 2GB and smaller.
Sep 18, 2010 | Kodak EasyShare CX7430 Digital Camera
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Memory card
this cam will work up to 2gb sd/mmc
what's the capacity of your card? if it's above that, it's really not gonna work with this cam
if your card is 2gb or lower
2 possibilities:
defective card - please try another card
camera memory reading problem - arrange repairs with kodak
Jan 20, 2008 | Kodak EasyShare C663 Digital Camera
Kodak camera cx7430
The maximum card supported by this camera is 2gb, any higher volume SD cards will not work. Also it could your card is not genuine or sometimes incompatible, without necessarily being 'broken'
Jan 12, 2008 | Kodak EasyShare CX7430 Digital Camera
Memory Card Format Fail
Hi I think its a compatibility issue. Try formatting it using your camera. else format it using Windows.
Sep 14, 2007 | Kodak EasyShare CX7430 & EasyShare Printer...
Kodak EasyShare CX7430 Digital Camera Logo
169 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
