Question about Refrigerators
Fridge only blowing tepid air in top and freezer sections. Condenser fan replaced today but hasn't cut in yet .
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 11, 2011
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Is it normal for warm air to blow out of the fan at the top of a side by side sub zero. Its over 20 years old and we recently had the compressor replaced on the freezer side.
warm air will blow out from the condenser fan which is in the same area as the compressor.
There should be no warm air inside the freezer of fridge.
Jul 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
I have a Whirlpool Gold refrigerator, model GB9SHDXP, about 2 and a half years old. It has a bottom freezer. Yesterday I noticed that the food in the top part were not as cold as usual. I came back...
ok,when you open the freezer door do you hear the fan blowing?all that happens is the freezer gets cold,a fan in the back wall of the freezer turns on and blows cold air up into the fridge section,a thermostat tells it when it's cold enough or it's getting warm then it will blow more air up top,if the freezer is working correctly then either the fan isn't working or the bottom freezer door was left open,warm air got sucked up into the air vents causing water droplets to be formed,then they freeze blocking the air vents with ice and now the cold air can't go into the fridge section.is there any ice on the ceiling of the freezer or frozen water droplets on the bags in the freezer?if so the door was left open.unplug the maction,and with a hair dryer blow the hot air into the holes on the back panel,keep doing this until you don't see any more water draining through the holes,turn it back on and see if the cold air is blowing up into the fridge.if the evap fan motor is bad the part number is W10128551 and it's around 25 to 30 dollars.you must of got the model number off of the book,it's not the full model number,check in the fridge section on the right hand wall near the ceiling and you should see a tag with the number on it.also down at the bottom kickplate,you can remove the kickplate and there should be a tech sheet tucked away in it,read it and it will tell you how to put the machine into defrost mode,if you can do this,instead of unplugging it if you have to melt it out with the hair dryer you can put it into defrost so the heater will come on and this will help you to defrost the vents quicker.let me know what you find and if you need any more help.good luck with your machine
Apr 12, 2011 | Whirlpool Gold GB9SHDXP
My refrigerator side isn't cooling the freezer is fine on my GE Monogram Model zisb42dca
Possible faulty freezer fan motor. Dirty condenser. Faulty control board.
Feb 23, 2011 | GE Refrigerators
Freezer works, fridge does not. Also the sides of the fridge are really hot but not up the top near freezer section. Fridge has recently been moved. Thanks
Warm sides are usually caused by the condenser fan which is underneath around back not running. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
When it was moved, was it laid down? If it was it should be stood upright for 24 hours before being plugged back in.
Feb 13, 2010 | Refrigerators
Freezer works, refrigerator does not cool
Often the cooling section is located in the freezer and their is a hidden fan that blows the cold air into the lower section. If the fan quits working the refrigiator section wil not be cool.
Jun 19, 2009 | Refrigerators
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Oct 24, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Indesit Fridge Freezer
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing (by compressor), Check recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side
Sep 08, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
