Question about Dryers
Ge front load dryer not heating three years old model # dbvh520ej2ww
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 11, 2011
Dryer only heats on the highest heat setting
Some electric dryers have two heating elements. You probably have one bad heater and one good heater.
Apr 14, 2010 | GE DVLR223 Dryers
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
My GE dryer, model DBVH520EJ2WW, is taking a very long time to dry clothes - up to 92 minutes! I cleaned the vents, but was wondering if it might be a problem with the thermostat. The loads are medium to...
SOME GE'S HAVE A TWO STRAND HEATING ELEMENT. ONE STRAND CAN BREAK AND THE OTHER ONE CAN STILL HEAT. IF YOUR VENT GOES UP THROUGH THE ROOF IT CAN BE CLOGGED AT THE VERY TOP ALSO, I HAVE SEEN THAT MANY TIMES. PLUS MAKE SURE YOU DIDN'T KINK THE VENT WHEN YOU PUSHED THE DRYER BACK IN PLACE.
Jan 15, 2010 | Dryers
GE Adora Dryer spins but no heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Aug 05, 2009 | GE WSXH208A Front Load Washer
Dryer heats with smaller loads
1. unplug your machine and rach as far in the exhaust part of the dryer to see if there is an obstrucxtion
2.Take out the lint filter and make sure there are no gaping holes in the screen
3. Check the exhaust house leaving the machine or blockage, this hose should not run more than ten feet for optimal drying time.
4. its your heating element
Jan 19, 2009 | GE DBXR463EBWW Electric Dryer
My GE Driver will not heat
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
Dec 26, 2008 | GE DBSR453EBWW Electric Dryer
HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Mar 17, 2008 | GE DCSR483EA Electric Dryer
Dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
Dryers Logo
238 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
