Question about Panasonic Televison & Video
Tv has sound although no picture model tyst42px5w
  • Panasonic Master
  • 5,163 Answers
It's probably a backlight or backlight inverter issue if the problem occurs on all sources and the onscreen menus. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx. Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Mar 11, 2011
Tv comes on for about 5 min. then picture gose out
Need more info. Does the power shut off when the picture go's out? Or do you have to turn the TV off although there is no picture, is there sound?
What is the Make and Model of your TV. This helps identify common issues with models. It is good to include Make and model anytime you post questions of this nature,
Feb 18, 2012 | Polaroid Televison & Video
I purchased this hdtv new from Best Buy in February 2008. Last week a crackling sound began to develop and now the sound has gone completely, although the picture is fine.
Insignia T.V. 50" Model; NS-PDP50, Plasma T.V.
T.V. comes on, there is sound but no picture.
T.V. is les than 18 months old. We use the T.V. when we come to our Condo in Daytona Beach for vacation, so it hasn't been used very much.
Jan 10, 2010 | Insignia LCDTV26 26 in. Television
My tv screen hv179 has sound no picture,
While the TV is on, take a flashlight and shine it on the TV, close enough to attempt to see any picture. If you see picture then your inverter board is bad. If there is a backlight but no picture then your video board is bad.
Nov 02, 2009 | Televison & Video
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Aug 24, 2009 | RCA F27442 27" TV
No picture, no sound
we need a request on what the blinking red light means on your model number and manufacturer of TV, we can then try to see what the blinking light means,(although it doesn't sound good) You ca always unplug the DVR and see if there is a change, then you would know it was the DVR
Thanks for the rating
Apr 12, 2009 | Televison & Video
Sony 27"TV will not turn on
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
Apr 07, 2007 | Sony KV-27FV16 TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
Televison & Video Logo
115 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
