Question about CTX EzBook FC3A300 Notebook
Windows updated last night now monitor has blank screen w blinking power light plugged another monitor in works fine how do i fix this monitor
  • 1,591 Answers
I don't know what version of windows you could possibly have os a 300MHz pII class K6 processor machine that would actually update...but it sounds like it''s switched to the external monitor.
If memory serves, it's FN+F4 or Fn+F5 but some combination of the function key and one of the F-Keys should fix it.
Posted on Mar 11, 2011
  • Norman Skinner
    Norman Skinner Mar 11, 2011
    It may be sleeping too (although you usually don't get an external display during sleep mode). try FN Wake. If that doesn't work, unplug it and remove the battery for 5 minutes, then put the battery back in, plug it in and power it up.
    President:
  • 1,623 Answers
Right click on your desktop and click properties(XP) or screen resolution(vista/Windows 7) on xp click on settings then see if you have two displays showing, if you have click on the one that is greyed out and click on extend my desktop onto this monitor and then click make this your main monitor click apply and click ok if your laptop screen shows your desktop its all good
AH59-02402A REMOTE, WAS WORKING FINE LAST NIGHT AND EVEN THOUGH THE LIGHTS BLINKED ON IT I TRIED NEW BATTERIES STILL WILL NOT CONTROL BOX???
If it show it was doing updates, Thats probably why it wouldn,t work .Once it has updated ,IT will (Probaly) Work (Again)
Nov 07, 2012 | Televison & Video
Screen went blank and orange light is on
fiona_sheeha, If ACER warranty service not an option, then unit will need local tech to troubleshoot unit's power supply/inverter circuit for possible COMMON and repairable printed circuit board fix. You must read more of my fixya profile and visit the web links you find there so you will know and understand what ALL your options are!!! Some units require less than $5 in parts to refurbish them to working status. Your "cold-cathode-fluorescent-lamp" backlit LCD monitor isn't any different than any other brand of monitor in it's basic operating principles!! I hope this helps. 12fixlouie
Dec 30, 2009 | Acer AL1916W 19" LCD Monitor
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
Mar 27, 2009 | Samsung 941BW LCD Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
Blue power button flashing with blank screen
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jan 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
LG L1917S - Blank Screen, Blinking Power Light
The bulb is dying in the back. These monitors are famous for it. You can look on ebay for a new backlight, but It's not easy to find.
Dec 29, 2007 | LG L1917S-BN 19" LCD Monitor
No Display
I have the same problem - the blank/black screen and blinking green power light. The speakers on the monitor work (I can hear the start-up sound that Windows makes), but the screen is blank. We bought the monitor on Halloween Night 2003 at Best Buy and had zero problems to date...except for last night. The Best Buy gang told me this afternoon that it was an internal hardware issue. I called the manufacturer and the tech guy confirmed the problem by saying he was almost positive it was the internal "inverter board" - which means you have to send it in to get it fixed. I guess this is a fairly common problem with these monitors by the way he made it sound. So, that's a $70.00 deal (service, parts, labor, and shipping back to your house) - that is, if there are no other issues with the screen itself - then the cost goes up. So by the time you pay to send it to them and then pay them to fix the board - it looks like you're better off buying a new flat panel monitor. Yikes. Anybody else with any suggestions - other than buy a new one? Thanks!!
Oct 19, 2006 | Mag Innovision LT776s 17" LCD Monitor
CTX EzBook FC3A300 Notebook Logo
77 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
