I WENT UNDER SOUND AND AUDIO AND IM NOT ALLOWED TO CHANGE THIS OPTIONS
    Novelist:
  • 134 Answers
Are you using an account with administrative privileges? If not, log into the account that DOES have admin privileges and change the settings for the account you use. Otherwise, Windows will keep you from making changes.
Posted on Mar 11, 2011
How do i change my proxy settings on my android so im allowed to download certain apps
A solution for WIFI:
  1. Connect to a WIFI network
  2. Settings->WIFI
  3. Long tap on connected network's name
  4. Modify network config-> Show advanced options
  5. Set proxy settings Manual or proxy Auto-Config
Nov 01, 2015 | Android Cell Phones
My garmin 660 won't transmit audio through speakers or fm transmit. I go to audio output and it says that "Audio output can not be changed when using headphones" I can use it with headphones...
You have a problem with the headphone jack. Please see this link and read the section about BROKEN HEADPHONE JACK
http://www.sharc.net/gps_audio_repair.htm
Because there is a broken connection, your Nuvi thinks there are headphones connected at all times, so you wont be allowed to change the sound options. I've repaired this problem many times. Don't try it yourself, you risk damaging your Nuvi beyond repair.
- Jim
SHARCNET-USA
Jul 19, 2011 | Garmin Nuvi 660 GPS Receiver
Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not...
hi, here are some solution plz try them all..
1. Have you tried updating the sound card drivers to their latest version?
Don't just check Windows Update, but the card manufacturer's website as
well.
2. Here is a simple quick fix!!!!!!
Open the Media Player
At the top, Click on "Tools"
Select "Options"
Click on the "Devices" tab
In the list of devices, double-click on "Speakers"
Under 'audio device to use' it probably lists your sound card ...THIS IS WRONG!!! !using the selector button on the right side of the window, change this
setting to:
"Default Directsound Device" (Note that "Directsound" will show as one
word).
This problem happens because MS never should have allowed this setting
to be changed ... it's senseless.
3. Click Start, then Run. Type dxdiag, then click OK. Choose the sound tab. You should see your device and driver there and you can even test the sound. If there is no device or driver, just install it and check it with dxdiag again.
Hope that helps,
Regards,
Pankaj
Oct 11, 2010 | Computers & Internet
Toshiba tv, model cf32c50 has a garbled sound issue.
distorted sound sometimes accompanied by buzzing is caused by detuned circuit in the SIF amplifier and sound detector circuit. a distorted sound alone is caused by a breakdown in AF amplifier circuit so try to change the sound ic since its the only options left. good luck!
Jul 27, 2010 | Toshiba Televison & Video
Hi . im searching for a audio-driver under windows 7 .
These are the steps to setup and 'restore' the "Audio Drivers". Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel. Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues." In the See also: (Category), click, on “Audio Devices, and Sound Themes.” Click, 'Playback', next, click on the 'Active' "Speakers". Click 'Configure' to "Audio channels" The (Speaker Setup) "wizard", appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on 'Enhancements', "Apply" changes. “The (Advanced), “not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply!, before exiting.
Jan 30, 2010 | Toshiba Satellite P105-S6104 Notebook
To play my vietcong game i have to disable sound otherwise it crashs
I had the same problem and solved it by selecting "Disable front panel jack detection" in the Realtek HD Audio Manager "Connector Settings" dialogue box.
Running Windows 7 Ultimate 64-bit on an ASUS P6X58D motherboard w/ integrated Realtek audio chip.
Aug 02, 2009 | Jack Of All Games Vietcong for Windows
Built in speakers not working
Please try to check it from Control Panel > Sound, speech & audio devices > Sound and Audio Devices > Hardware tab > then select the Device Name then click Properties tab to verify its condition status or you opt to click Troubleshoot tab. regards
May 12, 2009 | Proview PX 780 Monitor
My skype sound keeps fading in and out.
Change skype sound setting. TO do that :
Take Tools from the menu bar.
Then select options.
When a new window opens choose audio Setting.
Then below microphone volume untick - "Automatically adjust microphone setting".
Then drag the volume to maximum.
Mar 15, 2009 | Skype IM
No sound alert on incoming messages in Skype 4
Here is my experience. This drove me nuts for a while but it works now.
I had the same problem with 4.0.0.206. I played around with mute/enable in Options/sound and Options/audio settings. I changed to ringing to my laptop speakers and now it all works. Go figure.
Feb 11, 2009 | Skype IM
Change sounds of messeges and buttons?.
to change the sound of your of your text messages...go to im not sure where it would be on your phone due to the fact that mine is from australia ... but i went to the section Audio and Ringtones under Alert Type and the options were there for me
Jul 20, 2008 | LG Shine KE970 Cellular Phone
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
