Question about Samsung Televison & Video
No image or picture come while power light is on and on/off button not working
  • 1,591 Answers
Click here for my last solution to similar issue (with videos)
Posted on Mar 11, 2011
LC-40le550u no picture... green light on
if powers on and has no video and no audio could be the main board, but first try this :
take a flashlight, turns on the tv and try to "see" the image while light up the flashlight against the screen , if you "see" something you have a bad back light inverter board.
below the posible parts number :
MAIN BOARD : Sharp 9JY0140CTJ05100
POWER SUPPLY/ BACK LIGHT : Sharp 9JY0940CTJ05000
TRY TO LOOK FOR AT :
www.bostonrecycling.net
or ebay
thanks
Oct 09, 2014 | Televison & Video
I have a Toshiba 47hl167 and when I plug it in and hit the power button the green light comes on but no picture?
The real issue is do you have sound or not?
You can unplug the set and or a box both if connected for several minutes and then power back to see if when they reboot set works or not.
Dec 10, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I cant see the person im taking a picture of on the LCD, its black.
This is due to the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD issue is there in the Camera.
If this happens only with the live view, then try resetting the Camera.
The RESET button is located at the lower right side of the control button. To reset the camera, press the RESET button using a sharp-pointed object.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Jul 24, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
The ON/OFF button blinks but no screen image
Since the power led button is on, I think the picture board on your monitor is faulty that is why it is not displaying anything.
Since your computer work perfectly with other monitor, it means the picture board is bad that is why it is not displaying any image.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Acer AL1716 F Monitor
Suddenly no picture and no sound all three lights flashing
First make sure to hit the menu button on the TV's remote and if nothing is there then while the set is ON turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
Cost of backlights is around 150.00 and power supplies around 100.00.
Mar 21, 2010 | Samsung DLP HL-P5663W 56" TV
No picture, just a red blinking light
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Feb 07, 2010 | RCA Televison & Video
A drop image on screen
hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
plz have me solve my problem
sam_rav
Jan 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Problem with picture it is very dark
hi,
Just a guess,under the power button, inside the the flip[ down cover is a light dimmer,you can turn this on and off,in advanced settings under video,a flash light will trigger the sensor to see if it works the dimmer,if not it could be that circuit or your power supply needs work,I hope this helps!
Dec 01, 2006 | Hitachi 43FWX20B 43" Rear Projection...
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
