Question about Diamondback Apex
How do i raise the handlebar stem on my diamondback apex? i am trying to install a child seat on the stem.
  • 74 Answers
SOURCE: diamondback rm 20 kids bike. Can you adjust the handlebars?
Yes, there is an allen screw on the top of the stem of the handle bars.....it may also be a bolt with a head on it that can be turned with a socket or cresent wrench.
Loosen the bolt 3 or 4 complete revolutions and then wiggle the bars back and forth from side to side while pulling up. Be careful not to completely remove the screw as the piece that it is connected to will fall off and you will have to remove the bars completely to fix.
Posted on May 03, 2009
dunnbiker
  • 8546 Answers
SOURCE: cannot raise handlebars on diamondback octane 24
You're right. A real bike shop would be able to swap out the stem and add riser bars or whatever you may need.
Posted on Mar 31, 2010
Coachphil
  • 347 Answers
SOURCE: What size allen wrench do
It is generally either a 5mm or 6mm depending on which bolts you are looking at. Sometimes they are SAE instead of metric but that is rare.
Posted on Dec 27, 2010
dunnbiker
  • 8546 Answers
SOURCE: can handlebar for ccm vandal
The threadless stem style you have pre-supposes you chose the right height and reach when you bought the bike. As the steerer tube to which it clamps has to be below flush with the top surface to accomodate the top adjustment cap, the steerer had to be cut to a final length that can't be made longer. The stem CAN be flipped upside down to provide a different rise and reach, but most likely it would be lower and farther away.
One option is to replace the stem with one with an angle and length that would work for you. Have a bicycle shop asist you in choosing one as there are 4 parameters that must be considered.
Another is to get a threadless stem riser which effectively makes the steerer tube taller. Google "threadless stem riser".
Here's one on eBay...
http://cgi.ebay.com/New-SATORI-HEADS-UP-Threadless-Stem-Riser-Adapter-1-1-8-/300530665912?pt=Cycling_Parts_Accessories&hash=item45f90609b8
Posted on Mar 18, 2011
dunnbiker
  • 8546 Answers
SOURCE: can you add a child seat to the diamondback
That would depend on the specific child's seat and what it requires for attachment points. I imagine the smaller bike frames might limit the ability to maintain clearances between the child and moving bike or rider parts.
There are a number of different schemes. Try these...
http://www.google.com/search?hl=en&biw=1242&bih=964&gbv=2&tbm=isch&sa=1&q=child%27s+bicycle+seat&aq=f&aqi=g1&aql=&oq=
Don't forget safety...
http://www.livestrong.com/article/113991-child-bike-seat-safety/
Posted on May 21, 2011
Adjust handlebars
you can't raise the stem on a Aheadset type stem/headset, they are not designed for it from the manufacturer.
Apr 17, 2014 | Diamondback Grind 20 Boys' Freestyle BMX...
Can handlebars on diamondback insight 2 be raised?
typically not, they use an Aheadset style headset. If you need them higher then your dealer or local bike shop can help you pick out a stem that has more "rise" to it so you can sit more upright.
Jan 19, 2013 | Diamondback Insight RS 700c Men's Hybrid...
How do I raise the handle bars on a Diamondback Sorrento? Purchased new in June. 16" frame, 26" wheels.
Web search teh question "How do I raise the handlebars".
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Aug 07, 2011 | Diamondback Cycling
Trying to raise handlebars ob Diamondback Sorrento.Attempts to loosen "ringnut" ,(CCW) at frame and handlebar stem, unsucessful with moderately high torgue; afraid to do the 500# gorilla as...
Aug 06, 2011 | Cycling
How do I raise the handlebars on Diamondback Overdrive Bike?
http://www.sheldonbrown.com/handsup.html
Jul 25, 2011 | Diamondback Racing Team Dbr Sticker Decal...
How do i raise the handlebars on the sorrento? I love this bike but my man parts go numb because I have to lean over so far due to the seat height level I require as I am 6' 3" Please help!
Jun 28, 2011 | Diamondback Sorrento 26" Mountain Bike
What size should I get?
A bike is the right size when your child can:
•Sit on the saddle and rest the balls of both feet on the ground.
•Straddle the top bar with a comfortable clearance and with both feet flat on the ground.
•Reach the handlebars with a slight bend in the arms when sitting on the seat. If there are handbrakes, your child should be able to grasp them and apply enough pressure to stop the bike.
•ByK bikes have more knee room than other bikes, which helps to lengthen the life of the bike and make the bike handle in a more predictable way.
As your child grows, you can raise the seat post and handlebar stem according to the owners manual limits.
Dec 16, 2010 | Cycling
Raise handle bars
At the centre of the handlebars you will note a bolt head that is separate from the ones that lock the handlebars in place. Undo that bolt in an anticlockwise direction. About three full turns should be sufficient. Now take a block of wood and place it on top of the nut to protect the surface of the nut. Get a friend to hold the bike steady because you will need both hands to keep the block of wood on top of the bolt and deliver two sharp blows with a hammer. The handlebars should now be able to be pulled up and down or at least twisted and pulled up and down. Tighten the bolt at desired height
Oct 05, 2010 | Raleigh Diamondback Joker Bicycle '10
How do you raise the handlebar of a Schwinn Ridge AL 26" bike? I want to add a child carrier and I need to raise the handlebar to make it fit.
The handlebars stem is an Aheadset-style and as such has spacers below it to set its height. Once the steerer tube is cut to fit the combination of stem and spacers there's no going UP, only down. Stems can be replaced with different rises and lengths. Maybe that would help. A Bicycle Shop would have everything you need and the know-how to decide if you can mount the child carrer.
May 27, 2010 | Schwinn Ridge Al 26" Men'sboy's Mountain...
I need to raise the height of my handle bars.
I am not sure which question to answer, so I will try both.
raising the handlebars, loosen the stem bolt 4or 5 turns, (this is the bolt on on the top of the handlebar stem). Tap the stem bolt with a hammer, the bold should drop down and the handle bars should fall loose, adjust as needed, then tighten the stem bolt to set.
Please note, there is usually a limit line on the stem, do not raise bars above this level as iy will make the handle bars unsafe and could pull out or break off.
second question, Child seats ar very adaptable, an will fit most bikes. Be sure to use all the necessary hard ware and safety guards. for you and your passenger.
Try to get the seat set up as low as possible as the higher the seat the higher the center of gravity. It will have less effect on handling characteristics if you keep the seat low.
I hope this is of some help.
Ed
Feb 01, 2009 | Schwinn Mesa Gs Mountain Bike
Diamondback Apex Logo
98 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
