Question about Casio FX-115ES Scientific Calculator
I want it back to norm and off of fix mode - Casio FX-115ES Scientific Calculator
  • 80 Answers
There should be a reset switch on the back of the calculator that you would stick a paperclip or pen tip into. When pressed, the calculator will reset to factory settings.
Posted on Mar 11, 2011
My calculator Casio FX-300MS suddenly shows one decimal place only and i need it for exams. please help
Press the MODE key repeatedly until you get to the "Fix Sci Norm" screen. Press 1 to select Fix, then press a digit specifying the number of digits after the decimal point, or else press 3 and select one of the Norm modes.
See the second column of the manual: http://www.fixya.com/support/p186611-casio_fx_300ms_calculator/manual-710
Nov 30, 2013 | Casio FX-300MS Calculator
How to stop the caculator from rounding off decimals. |t doesn't give any accurate answers. e.. 0.789 will become 1
Two choices: Press the MODE key a number of times until you get to the "Fix Sci Norm" screen, press 3 to select "Norm" and then press 1 or 2 to select one of the norm modes.
Press the MODE key a number of times until you get to the "Fix Sci Norm" screen, press 1 to select "Fix" and then press a digit specifying the number of digits you want after the decimal point.
If you need a manual you may download a copy here. The display modes are discussed on page E-15.
Dec 23, 2012 | Casio FX82MS Scientific Calculator
How to cancel fix mode
If your calculator has a mode key, try pressing it repeatedly and see what is displayed. If you see FIX, SCI, ENG, Float or NORM, press the key corresponding to float or Norm (if there is no float).
If your calculator has a key next to which is the FIX marking, look around to see if you can find SCI, ENG, Float or NORM. Select Float or Norm
Jul 30, 2012 | Office Equipment & Supplies
Answer only carries out to 4 decimal places
Press the MODE button until the screen shows: [Fix Sci Norm] for the display mode, then press the number corresponding to Norm (ie 3 for Normal) then either 1 or 2. Display mode Norm1 shows numbers that are less than 1 in scientific mode, whereas mode Norm2 retains decimal format where is fits on the display.
Nov 22, 2011 | Casio fx-300ES Calculator
How can i get fix off my calulator
To get out of the fixed decimal mode, press the MODE key until you see the screen giving you the three options "Fix", "Sci", and "Norm". Select Norm 1 or Norm 2. If you select a Sci mode, you'll get "SCI" on the screen in place of the "FIX".
Jun 23, 2011 | Casio FX-300MS Calculator
HOW CAN I GET FIX AND REG OF MY CALULATOR.I AM USING FX 300MS.
Press MODE 1 to get out of the regression mode and into the standard calculation mode.
Jun 23, 2011 | Cameras
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
How can I get my calculator out of scientific notation mode? It is a casio fx 300ms
Please press the Mode button on your calculator repeatedly till you get the following screen
Fix Sci Norm
1 2 3
Press 3 from your keypad and the screen will change to
Norm 1~2?
Press 1 from your keypad and your calculator will be normal again i.e out of scientific notation mode.
Mar 15, 2011 | Casio FX-300MS Calculator
How do i take off scientic mode just a regualer:
Press SHIFT [SETUP]. You can select FIX for fixed-decimal or NORM for normal display. For FIX the calculator will prompt for the number of digits. NORM gives you two choices: 1 will display numbers of magnitude less than 10E-2 in scientific notation, 2 won't switch to scientific notation until the magnitude drops below 10E-9.
Sep 21, 2010 | Casio FX-115ES Scientific Calculator
I have fix and deg on my fx 992s and I am only getting results and can only enter numbers to 1 dp. How do I remove this?
Ok. Press [MODE] key three times until you see a screen that shows Fix SCI and NORM. Under FIX you have 1, under SCI you have 2 and under NORM you have 3.
You cannot remove FIX, unless you replace it with another display MODE (SCI or NORM or ENGineering).
You cannot remove DEG unless you change angle unit to RADians or GRAds.
To set angle Unit You start by pressing MODE twice to get a screen that displays DEG, RAD and GRA and below them 1, 2 , qnd 3. If you press 2 the angle unit will be set to Radians. DEG will disappear, but RAD will be shown.
Whatever the display format for numbers (FIX, SCI, NORM, ENG) you can always enter numbers of any length. It is their displaying that is affected by the FIX,SCI, etc. mode.
If you want more than 1 decimal digit, press [MODE] three times, then select 1: FIX. You will be asked to select the number of decimal digits (from 0 to 9). You could take 2, 3 or 4, or anything you want.
  1. To summarize: Indicators on screen reflect the configuration or mode you are in.
  2. They can be replaced by others but you cannot clear the screen of the indicators.
  3. You can select the number of decimal digits in your results,
  4. but there is no restriction on the numbers you enter.
Mar 03, 2010 | Casio Office Equipment & Supplies
Casio FX-115ES Scientific Calculator Logo
125 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
