Question about Motorola Mobility RAZR V3
Motorola RAZR V# has lines running on LCD
When I open my Motorola RAZR V3 cell phone, I see horizontal lines running at the bottom and I noticed they are increasng from bottom to top day after day. I've done a basic reset by removing the battery and re-installing it but it doesn't resolve the problem. May I get help on this.
  • Anonymous Oct 08, 2008
    I have lines at the bottom of the screen that won't go away and they are increasing. My phone is less then 6months old. A Lemon?
  • 1,586 Answers
It sounds like the phone is starting to fail. These phones are great while they work, but my first two both died a little under a year after I got them. I have one now, and when it goes, I'm switching to an iPhone. At least that way I can deal with new problems:)
Seriously though, your phone's ribbon connector (between the two halves of the phone) is starting to fray or fatigue from opening and closing the phone, and you're losing conduction through it to the screen. The problem will likely get worse until the phone dies. It stinks, but this seems to be normal for these phones.
Posted on Aug 01, 2008
How to open by another sim
HI if you want to open Motorola Razr v3 mobile to other network sim .Then have a look at sites like http://www.theunlockspot.com/motorola-razr-v3/rs1wp9/ here they are rendering code to remove network lock for all model phone .You can make use of it and unlock your phone from its present network provider and freely use it with any GSM sim ...
Jan 08, 2014 | Motorola Mobility RAZR V3
Blue screen, says Bootloader USB Init at bottom, won't restart with power key
1.go to http://www.modmymobile.com
2.download p2ktools zip file
3.extract zip file
4.down firmware for motorola razr v3 zip file
5.extract razr v3 zip file
6.open p2ktools extracted folder open p2ktools exe file
7.read help how to flash your motorola razr v3
Aug 24, 2011 | Motorola Mobility RAZR V3
My Motorola Razr v3 cell phone's lcd is blank
unscrew it and change the flex to enable it view programms
Jul 17, 2009 | Motorola Mobility RAZR V3
Motorola RAZR V3 freezes when camera or video is used.
Depending if it has worked in the past, a hard reset may solve your issue. if not you will need to reflash your phone
Apr 19, 2009 | Motorola Mobility RAZR V3
Open line for Motorola Razr v3
try online at unlockitnow.com or mobile2mobile.net or try a mobile shop and have them unlock it for you.
Oct 16, 2008 | Motorola Mobility RAZR V3
Unlock phone
Unfortunately there is no such thing as a Motorola unlock generator or free motorola unlock code, as such there is no way to unlock your Motorola Razr-V3 for free, Motorola randomly generate the codes so they have full control over unlocking Motorola Razr-V3, However you can get the unlock codes To Unlock Motorola Phones FAST and at very reasonable prices from the given websites.
www.motounlocknow.com/motorolav3.htm
www.cell-unlock.com/motorola-v3-razr-unlock.htm
Hope my info helps you....
Thanx for using fixya......
Sep 26, 2008 | Motorola Mobility RAZR V3
Bought razr v3 'key lock code'
o codigo de segurança de Motorola V3 está bloqueado
Sep 03, 2008 | Motorola Mobility RAZR V3
Razr inner screen fading, flickering
take the phone and have the LCD replaced on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Dec 07, 2007 | Motorola Mobility RAZR V3
Problem with display
LCD is very fragile. Over time it will get worse. I suggest to get a new screen for about 30$
Mar 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
63 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
