Question about Brother MFC 420CN All-In-One InkJet Printer
See troubleshoot and routine maintenance chapter in user,s guide. Init unable 4F
  • Brother Expert
  • 159 Answers
You really should mention the brand and model of the printer, but from the message, I'm guessing this is a Brother inkjet machine. If so, the Init Unable message means that either the printhead is unable to go back and forth, or it can, but the machine doesn't know it can. The most common causes are:
  • A scrap of paper got wadded up in the way of the printhead. It's probably crammed up against one end or the other of the area the head travels through. Usually it's soaked black with ink and stuck in the right-hand end where everything else is black, too. If you unplug the power, you might be able to pull the printhead out of the way by hand to get at the scrap. You'll need a flashlight and maybe long tweezers. See the note below about the gray film strip.
  • Sometimes it's more serious. The right-hand end, where the head parks itself is a cleaning/sealing station. Between jobs, the head rests there, and a motor lifts rubber seals up against the bottom of the head to prevent the ink nozzles from drying and clogging. If that motor died, the head is stuck over there, and a repair probably costs more than a replacement machine.
  • Sometimes it's less serious. You might be able to see a 1/4-inch wide strip of gray film stretched tight across the area the head travels through. The gray is actually fine vertical lines that the head counts with an optical sensor, keeping track of it's location, so every dot of ink goes where it ought to. Sometimes a paper jam pushes that strip up and out of its sensor, so the machine can't see it. If it can't count those lines, it assumes it must be jammed and throws up that error. You might be able to gently lift and drop the strip back into the sensor. It should be straight and vertical, all the way across, without anything rubbing on when the head moves.
  • Be nice to that film strip. It's just photographic film, and not made to be rubbed. Ink smears will blot out the lines and cause the error you already have, so keep dirty fingers off it.
There are other possible causes, but these are the likely ones, two of which you may be able to fix without parts.
Good luck.
Posted on Mar 11, 2011
Unable to clean see troubleshooting and routine maintenance chapter in user's guide
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
See Troubleshooting and routing maintenance chapter in User's Guide Init Unable 46
Init Unable 73
Jan 23, 2011 | Brother MFC 210C All-In-One InkJet Printer
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 210C with error code 4F
This will reset the purge count value. Then restart your printer and it should work just fine !
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
[HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Unable to print
ph is defective and needs replacing (4F: thermo sensor within ph)
Mar 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
1,450 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
