Question about Sony Playstation 3 (PS3) Console
My ps3 says system was shut down unproperly and is giving me the error code 80010517
How can I fix 8002F334 error in my ps3
I've seen this error code going around for the older PS3's. From what I can gather, it's a HDD issue that can't be cured easily. Here are the steps to take that I found, that seem to work for all PS3 systems.
  • take out the hard drive
  • connect hard drive to pc (running windows 7 64bit, but any windows os should work without other software)
  • open up disk management - in win7 it asked me to make a master boot record, so I did.
  • format in NTSF - that's right, NTSF - don't use quick format
  • shut down pc, take out hd, take usb drive too
  • put hd back in ps3, put usb stick in ps3
  • boot ps3
  • a screen will pop-up saying the hard disk have to be formatted
  • hold start + Select for 5 sec.
  • After formatting the system will restart and the update will start installing
  • configure your ps3 setup - done
  • Remember to get the latest firmware from SONY onto the USB drive.
Jan 12, 2016 | Video Game Consoles & Games
My PS3 have error code 8002f334
  • boot ps3
Sep 05, 2015 | Sony Playstation 3 (PS3) Console
80010514 ps3 error
Try this hold power button down until unit shuts off then hold down power button again watch the green led it will blink 2 times on the 2nd blink let go. it will come up with a menu to do things try #3 ..
Also that error looks like the sign on error when your network settings are not in the system.
Apr 18, 2014 | Sony Video Game Consoles & Games
I'm trying to purchase first strike and I keep getting an error code 807100092 for PS3. How do I fix this it was fine this morning I have the 250 or 260 gig PS3
Most of the time this error has to do with your internet connection. I would suggest you power off you PS3, unplug the power from your router for about a minute, plug it back in and give it a couple of minutes to boot up. Power up your PS3 and try your purchase again. This solves the problem most of the time so give it a try. Take care and good luck!
Mar 03, 2011 | Sony Playstation 3 40GB System Console
My ps3 reads system is to hot and shuts down within five minutes. I don't think the fan is working at all. No warranty how can I fix this myself? I know how to take ps3 apart and I've cleaned the dust out...
Try upgrading the firmware as well.. Or doing a factory reset..
The error code could simply be stuck, and an upgrade or system restore may fix the issue if you have already cleaned the fans.
Aug 17, 2010 | Sony Playstation 3 (PS3) Console
My ps3 gives me an error code 80710723 what shall i do
Hi sir
80710723 - error code
Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
How do i fix error 8002f1f9
1. reset ps3 to defaults using recovery menu. 2. begin installation using the same fw version. (hard disk must be formatted externally if u get error 8001002b)
3. when it hangs @ 73% or whatever. Shut down and remove the drive
4. begin the installation of the system inserting the drive into another ps3
5. after it reboots, press (PS), at the disclaimer shut down, remove the drive and put into the broken ps3
6. boot normally...it ask to format the drive...
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont load or play games, Just a blank screen.....
Try playing a Demo game, if you dont have any download it from playstation network. The point is just to force the sytem to play games and if you notice, movies and games are listed under a different folder in the icon's list, so playing a demo game will force the system to play the game and you should be able to play your games fine after that,. Thing is that a game's info might've got stuck in freeze mode when the system was shut off unproperly while a game disk was still inside, that's all. Good luck, dont wanna see any PS3 comrades suffering the unspeakable horridness of not been able to play games. Be strong my friend.
Mar 09, 2009 | Sony Playstation 3 (PS3) Console
Power Button
just install your ps3 demos on system use webbrowser on ps3 to download demos or store the ps3 canot be shut down by power button on system itself only from controller or turning back off then on hope this helps
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
103 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
