Question about Cell Phones
My lg cholate tuch wont turn on but the scren turns on when its charging and the batery is fine how do i make the end/power butten work
  • 23 Answers
The problem is from the Keyboard Flex Cable.It has either lost contact from the main board or it is completely damaged. If you have basic repairing knowledge,you may disasseble your phone and re-attach it properly. However,if that did not help,you may have to purchase a new flex cable to replace the damaged on. See what it looks like in this link ...
http://shop.ebay.de/i.html?_kw=LG&_kw=KG800&_kw=Chocolate&_kw=flex&_dmpt=Handy_Zubeh%C3%B6r
Posted on Mar 11, 2011
My LG slate tablet wont turn on
my son charged mine with the car charger for higher voltage charge and its working fine now
Dec 22, 2013 | LG 8.9" 32GB G-Slate Tablet
GE Model# D52GW12 Television works good for
The small signal board is usually at fault when that symptom occurs. You can get replacement boards from www.tvrepairworld.com
Apr 02, 2010 | Televison & Video
It wont crank like not getting power
ok sounds like you have a dead battery
1) if turns but slowly:
posible causes:
1.1) old dead batery/
or underchaged battery >check altenator in this case
did you leave your headlights turnt on and drained the battery of its charge?if so get a jump start and then run the car for 30-45 mins to rechagre the battery
if you have at your disposal anothere batery that you know has a good charge
try starting your car with that batery(not using jumper cables) hook it up!
if the slugish turn over is still there
1.2) check your wire conections for corision this means completly disconecting 1 lead at a time (only on one end of that lead)and cleaning them with a wire brush or some sand paper.
(on the battery and the starter also the ground strap conection to the frame.)
2) WONT TURN OVER AT ALL:
posible causes:
2.0) dead battery >try charging it>get a jump start
2.1) blown turnkey igntion fuse
2.2) blow fuse for main har nes wires
2.3) bad starter
2.4) corosion on wire conection (most often the batery terminals)
2.5) starter replaced and hooked up incorectly.
2.6) alram system preventing the turnkey igntion system from getting power
Feb 24, 2010 | 1994 Mazda 626
Why is my screen turning black right when I Press send?
i had the same problem do the ##program9700 thing mention above follow it all then after you press proximity cal you have to hold the phone next to your ear and then press ok.........this does so the screan wont go black when you make a phone call up until the point u put it up to ur ear.......if you bring it back down then the keypad will reapear.........
Mar 24, 2009 | LG Dare VX9700 Cell Phone
Bike will not start no power
Touch a 12" piece of wire to one terminal then touch the other end of the wire to the other terminal. Got a really good spark? No spark = bad battery. Okay, so you do get a good spark. Check the wiring harness for an unplugged wire. Also check for loose connections and burned wires. Bad ignition switch? Kill switch turned on?
Mar 13, 2009 | 2005 Honda CBF 500 ABS
Lg dryer
Sounds like you have a motor going out. If you take it back apart see how hard the motor is to turn by hand. Also look for lint in the motor by the start switch.
May 16, 2008 | LG Dryers
Strange icon on phone display
sounds like your bluetooth icon.
goto: menu....setting and tools......bluetooth.....
then there should be an option to turn bluetooth power OFF. Once you do the icon goes away.
Dec 03, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Tuch screen not working
the connection of the control button of the lcd panel is cut....check the flex wire of the lcd
Jul 19, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
