Question about ASUS Computers & Internet
Pc800 no sound - ASUS Computers & Internet
  • ASUS Master
  • 3,606 Answers
Down load the driver here:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Use the ASUS Navigation Wizard this will direct you to the site for the mainboard.
You need to unpack the file when down loaded.
You can install this: http://www.7-zip.org/
To unzip your file.
Good luck.
Posted on Mar 11, 2011
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/benjamin_29adbb94bfb43281
Sep 27, 2014 | Computers & Internet
98 HONDA PC800 DRIVEABILITY PROBLEM
Check fuel filter. starving for fuel.
Jun 06, 2013 | Honda Motorcycles
Whats max RDRAM I can install on A49507-903 ?
2GB.
The Intel Desktop Board D850GB has four RIMM sockets (two sockets for each channel) and supports the following memory features:
Single- or double-sided RIMM configurations
Maximum of 32 Direct Rambus devices per channel
Total system memory configurations from 128 MB (minimum) to 2 GB (maximum) utilizing 128/144 Mbit or 256/288 Mbit technology PC600 or PC800 compliant RDRAM
Serial Presence Detect (SPD) based configuration for optimal memory operation
Suspend to RAM support
ECC and non-ECC support
When installing memory, note the following:
The four RIMM sockets are grouped into two banks:
Bank 0 (labeled on the board as RIMM1 and RIMM2)
Bank 1 (labeled on the board as RIMM3 and RIMM4)
Bank 0 must be populated first ensuring that the RDRAM installed in RIMM1 and RIMM2 is identical in speed, size, and density. For example, the minimum system configuration would use two 64 MB RIMM modules of PC600 or PC800 RDRAM.
If the desired memory configuration has been achieved by populating Bank 0, then Bank 1 should be filled with two Continuity RIMMs.
If memory is to be installed in Bank 1, the RIMM modules installed in RIMM3 and RIMM4 must be identical in size and density to each other, and match the speed of the RIMM modules in Bank 0. The RIMM modules do not, however, need to match those in Bank 0 in size and density. For example, if Bank 0 has two 128 MB RIMMs of PC800 RDRAM, Bank 1 would require PC800 RDRAM also, however, any other supported RIMM modules such as 64 MB or 192 MB could be used.
If ECC functionality is required, all installed RIMM modules must be ECC-compliant.
Jun 08, 2012 | Computers & Internet
1990 Honda Pacific Coast 800 will not turn over
Hi, Bill before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
PC800 will not start Tips before take it to mechanic
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
http://www.pc800shopmanual.org/PC800SMContents.html
https://www.partsfish.com/page/oem-parts-for-honda
Honda 1989 PACIFIC COAST PC800 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 24, 2012 | 1990 Honda Pacific Coast
89 pacific coast honda need to install choke cable how do i get the cables hooked into the carb?
Hi, Vccansler sorry you can't find the first and best tool you ever bought for your Honda despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
PC800 carburettor tear apart Not Your Average Engineer
http://pc800.co.uk/mwf/attach/13/3413/pc800info.pdf
PC 800 Service Manual
PC 800 Owner Manual
Sep 11, 2011 | 1991 Honda Pacific Coast
1991 Honda Pacific Coast how to replace the choke cable
Hi, Richard for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
Choke Cable Replacement Honda PC800 Pacific Coast Forum
How to replace your choke cable GL1100 DIY Articles goldwingdocs com
Jun 15, 2010 | 1991 Honda Pacific Coast
Looking for the manual for a Gateway 700S PC. Specifically 2 questions ... 1) how do I open the ATX tower case? and 2) what EXACT memory specs do i need to upgrade this unit from the 256MB that it came...
for the memory upgrade, your system used RDRAM RIMMS.
it supports the following memory modules (which must be installed in pairs).
and as for opening the case, you there should just be ~2 screws on the side panel away from the motherboard ports that you can remove and it will slide off, or there might be 1 or 2 thumb screws.
64MB Module 64MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-136 128MB Module 128MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-079 512 MB Kit 256MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-081 64MB ECC Module 64MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-134 128MB ECC Module 128MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-080 512 MB ECC Kit 256MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-082
Jun 24, 2009 | Gateway 700 X PC Desktop
Memory limit for my dell E139761 motherboard
Although the motherboard ultimately decides how much memory your system can handle, Dell does not list the specifications of motherboards. You need the model number of the computer, and if the motherboard is not the original one that came in the computer when it was built by Dell they won't know either.
You can go to dell.com and put in your service tag to see the specifications yourself. If you post the computer model number or service tag here that's what someone else will do anyway.
Mar 23, 2009 | Dell Computers & Internet
Upgrading memory
pc 800-45 is also compatible. you can get that one.
Dec 18, 2008 | ASUS P4T-M Motherboard
HI!
the speed readings on your memory are the maximum speed that that memory can preform at. When you have different speed memory put in your computer it will run at the speed of the memory which is the slowest. i.e. you might have a pc800 but that baby's only running at 400 mhz or 533mhz.
Dec 03, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
