Question about Life Fitness T3 Treadmill
My life fitness T3 tredmill incline motor sounds horrible. Should I just put grease on it or what are some easy trouble shoot ideas
I love to work outmy life fitness T3 tredmill incline motor sounds - babygirl2100.jpg
Posted on Mar 11, 2011
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
INCLINE ERROR ON LIFE FITNESS 95 T TREAD??
hi
check the home switch
it is indicator of elevation
when you look under the tredmill where elevation motor you will see white plastick pin coming down through the hole just check it if still there and pressed it is usually 95 % of elevation problems
if it is not then open the hood and check elevation connections
let me know if it is not these problems post it i will give you system check code
thank you and good luck
Dec 04, 2010 | Life Fitness Exercise & Fitness
T3 - It slows down then speeds up, has mind of its own.
It sound like the Motor Control Board is failing call Life Fitness @ 1-800-351-3737 they will give you additional information and locate a servicer in your area
Jun 12, 2010 | Life Fitness T3 Treadmill with Advanced...
I work on Bagram AFB in Afghanistan and have a 95
Go To Gymparts.com click on Diagnostics and Repair scroll down you will get in on trouble shooting your problem.
Jun 03, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
Life Fitness T3 Treadmill Logo
152 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
