Question about Ricoh Aficio SP C232DN Laser Printer
How to clear toner collection bottle sign for Ricoh_Aficio_SPC232DN
  • 52 Answers
Replace the waste toner bottle (toner collection bottle)
Or dump the waste toner from it and clean it thourghly.
Posted on Mar 10, 2011
  • David Vannucci
    David Vannucci Nov 15, 2012
    You must make sure the see through window on the right is clear. This is how the machine checks the toner bottle is clean.
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
FUNCTION PROBLEM SC681-19 FOR RICHO SP C830DN
This is an error code for the RFID which is the toner bottle chip on the the toner bottles. I would suggest you check the toner cartridges for any damaged or disconnected chips, have you changed to non ricoh toners as this can sometimes cause a problem. Check each bottle if you have any old empty bottles insert one of these into corresponding colour slot and you can then see which bottle is causing the error. Failing this the board will need to be changed. I have had errors on non ricoh bottles. you can also vac out the slot to clear spilt toner. hope this helps
Feb 24, 2014 | Ricoh Aficio 2035 Copier
I want to empty my used toner bottle on a Richo Aficio 1232C. Where is this located? Is there any particular sequence to the changing? Robert
you study this copier.If you are not have user guide you collect it by ricoh copier support webside.
Thanks
Tareq Bin Mostaq
Bangladesh.
Aug 13, 2011 | Ricoh Aficio 1232C Color Copier
How do i change the toner colection bottle for a Ricoh aficio 350 copier?
There is no toner collection bottle for the 350, used toner is stored in the transfer belt unit. It must be pulled from the machine disassembled then empty used toner reassemble and put back in machine, a counter must also be reset, cant remember which sp code this is though.
Sep 16, 2010 | Ricoh Aficio SP C410DN Laser Printer
How repair error sc 590 in ricoh aficio 550
SC590: Toner collection motor error
-Definition- [B]
The toner collection motor sensor output does not change for 3 seconds while
the toner collection motor is on.
- Possible causes -
· Toner collection motor defective
· Too much load on the drive mechanism
· Poor toner collection motor connector connection
· IOB defective
· Toner collection motor sensor defective
Sep 06, 2010 | Ricoh Aficio 1224C Black and White Copier
How to replace waste toner bottle for Ricoh Aficio w3600
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Jan 21, 2010 | Ricoh CL3000E Laser Printer
Savin 2070dp error code sc496
SC496: Toner collection bottle error
-Definition-
The toner collection bottle set switch remains off when the front door is closed.
- Possible causes -
• No toner collection bottle
• Poor connection on the switch connector
Aug 24, 2009 | Ricoh Aficio 450 Copier
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Ricoh Aficio 650
I have a Richo Aficio 650 copier and get a error of CS496-00 does anyone know what this means?
Aug 18, 2008 | Office Equipment & Supplies
Ricoh Aficio SP C232DN Laser Printer Logo
430 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
