Question about ITec Portable Power Station wJumpstarter and 400w Inverter
Lost charger, need to know voltage and polarity of charger for this unit. Thanks.
What volt charger is needed for (cobra microtalk pr560wx)? Thanks,Richard
Hi Richard,
Volt Charger??? I'm not sure what you mean, but if you mean what voltage to recharge the batteries, then you need to look at the unit, all over to find the AC input, there should be something tht states voltage and polarity there, if it infact has one.
Pease reply with more detail re: your query.
Regards,
Peter
Jan 20, 2013 | Cobra Ga-cs Or Ga-cl Microtalk Charging...
Hi, I have lost the ac power cord for my NC-E2 Canon battery charger. Is there a similar cord I can buy from Best Buy or Circuit City that will fit? Thanks in advance. JD
You need a UNIVERSAL POWER CORD, NON-POLARIZED
you can buy at
http://www.allelectronics.com/make-a-store/item/LCAC-400/2-CONDUCTOR-POLARIZED-CHEATER-CORD/1.html
see these cables has round and square ends.(click Zoom and Look the picture)
If the hole in charger have two round corner buy
http://www.allelectronics.com/make-a-store/item/LCAC-390/6-2-COND.-UNIVERSAL-POWER-CORD-NON-POLARIZED/1.html
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Canon NCE2 NIMH Charger Battery Charger
I have a Kingavon 1 million cp spotlight (model SL1000EB ) I also have a lot of unidentified chargers. Does anyone know what charger fits the spotlight?
I will assume that your light has rechargable NiCad batteries. Use the following advice ONLY if you are sure this is true. If the light is more than a couple of years old, this is probably true. Of the plug has to fit, but it must also have the correct Polarity, Voltage, and Amperage. The spotlight should be labeled where you plug the charger into it with these three critical parameters. They will also be indicated on the chargers. POLARITY --- If it takes a round plug, the polarity is indicated by a symbol that looks like a C, usually with a plus sign inside of it (this indicates that the center contact is positive). VOLTAGE --- this will be expressed as VDC input on the light, and VDC output on the charger. The voltages only need to match within about 10%. AMPERAGE ---- this will be expressed as mA (milliamps, which is thousandths of amps) or as A (which is Amps). 1000 mA = 1 A. This doesn't need to match precisely either. But if it's too low, the charge will take a while and you might burn up the charger (possibly literally burning it). If the amperage on the charger is high, that's OK, so long as the voltage is not high as well.
I hope this helps, Thanks for using FixYa. Al Kupchella
Apr 29, 2010 | Safe International Digital Electronic Safe...
New wall Charger needed
Depends upon the model, but most use 12v 500Ma batteries w/ a barrel-pin connector.
You can buy one here, or search this site for your model:
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69262&tid=16032
Sep 22, 2009 | Vector 1 Million Rechargeable Spotlight
I want to know is what lagitech MX 5000 & MX 5500 they have the same charger thanks
if you are going to use 1 charger from the other unit make sure the voltage is the same and the polarity matches. almost all units have the polarity where you plug in the charger to the unit. (+ or - on the tip.
Jul 02, 2009 | Logitech Cordless Desktop MX 5000...
POWER ADAPTER
LOST POWER ADAPTER NEED TO PURCHASE NEW ONE
Apr 30, 2008 | TruTech PVS12701 Portable DVD Player
T5522
Yes I have fixed the problem thanks. If you like to know how you can join my premium plan costing just £12.99 a quarter.............
Touche
Mar 02, 2008 | Motorola T5522 (7 Channels) 2-Way Radio
Car Adaptor
here is an free 800 number you can call and ask the techs to make positive friend
Polaroid electronics
1-866-400-5168
Hope that fixya up there
Nov 19, 2007 | Polaroid PDV-0700 Portable DVD Player
ITec Portable Power Station wJumpstarter and 400w Inverter Logo
88 people viewed this question
Top i-Tec Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an i-Tec Vehicle Part and Accessory Expert? Answer questions, earn points and help others
