When I send envelopes to the printer, the printer is leaving ink marks on the edges of the envelopes
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 544 Answers
There is a possibllity that your ink cartridge at the printing nozzle has excessive ink.
Remove the ink cartridge and clean the face and edges around the ink nozzle
with a swab or paper towel.
Posted on Mar 11, 2011
Troubleshooting epson printer
Sometimes the problem is with the envelopes and the way they are made. Check the edges; Are they sharp enough? Also, the tray may be holding the envelopes too tightly and let them go at the wrong time: also check this.
Sep 07, 2014 | HP Hewlett Packard - Photosmart 7520...
Where do i put envelopes in a lexmark X6570
Loading envelopesYou can load up to 10 envelopes at a time.
Warning: Do not use envelopes that have metal clasps, string ties, or metal folding bars.
1 Load envelopes in the center of the paper support with the stamp location in the upper left corner.
2 Make sure:
• The print side of the envelopes faces you.
• The envelopes are designed for use with inkjet printers.
• The paper guides rest against the edges of the envelopes.
Notes:
• Do not load envelopes with holes, perforations, cutouts, or deep embossing.
• Do not use envelopes that have exposed flap adhesive.
• Envelopes require more drying time. Remove each envelope as it exits, and allow it to dry to avoid ink smudging.
Apr 11, 2012 | Lexmark X6570 InkJet Printer
I am printing envelopes and have black ink marks and streaks across the left hand side of the envelope (return address area).
There is dust & ink build up on the printer head. Take it apart. Wipe it off by hand with print head cleaner & lint free cloth.
Apr 05, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How do I load envelopes to print?
Load the papers/ envelopes from left hand side edge and adjust the knobs of printer tray to accomodate the paper, if present. Usually printer will have the seperate markings on the tray to indicate where to load envelopes and labels.
I hope this is useful to you
Oct 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Canon Pixma Ip4200 Ink Smudges
1. Do you use refilled or genuine Canon cartridges?
2. Anyway, try to clean the printheads, because they seam to leak.
3. Verify if the cartridges are correct alignet (in maintenance software you have soewhere an "align cartridges" function
Feb 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Ink smudging
Run a cleaning sheet through the printer- absorbant papaer- blotting paper. If this machine has had a lot of service it may be your waste tank is filling up and leaking out - have you had a service warning yet?
Sep 16, 2007 | Epson Stylus RX500 All-In-One InkJet...
MP460 printer--problem w/ envelopes
You seem to have clogged nozzles/printhead. Take out cartridges, do a thorough clean down where cartridges sit, the printhead, even the roller as well. Run your printers own cleaning maintenance before you do it manually with cleaning solution. Problem should be gone when you reinsert cartridges. Don't froget to reset ink levels and cartridges. good luck!!!
Aug 31, 2007 | Canon PIXMA MP460 All-In-One InkJet...
106 people viewed this question
k24674
jasbo
jasbo
