Question about Efficient Networks SpeedStream 5200 Modem
How do i acces my modem to get it out of bridge mode to use it without a router
  • 57 Answers
Hi paintballa12!
Here's the link for yor modem's userguide..
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
Normally, all dsl modems can be "unbridged" byr resetting it to factory state.. But that would mean you have to save you DSL username & password again..
Check page 38 for setting modem to non-bridge mode..
Hope this helps..
Posted on Mar 11, 2011
How do I find the bridge mode in sb6121
The Motorola Surfboard SB6121 is a cable modem only - no router included.
You must have a router - after the modem - in the network if you need router duties.
There is no bridge mode in the modem. Bridging the modem basically bypasses the routing function of the device and passes everything on to the next device in line......the router in this case.
Since this modem does not have a router built in - it is always in bridge mode.
Feb 03, 2015 | Arris Sb6121 Docsis 3.0 Cable Modem...
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
When I plug my modem into the computer, the internet works fine. But when I plug the modem into the router and plug the router into the computer, it don't work no more. And I can't get on from my laptop...
>You need to set the modem to Bridged Mode first, then connect the router to the modem so that all configuration will now be controlled by the router.
>Ask your Internet Service Provider on how to set your modem to Bridged Mode.
Oct 23, 2010 | Linksys Wireless-G WRT54G Router
II gave my router to my mother it has already been set up for an encryption I gave them the passkey and it is not working could this be due to the fact she has dsl internet and I had cable
>No, it really doesn't matter what type of service you have.
>To get it fixed just make sure that if your mom uses a modem and you hooked the router to it, modem must be in BRIDGED mode before you can make the router work.
>To set the modem to bridged mode you need to contact your mom's DSL provider so they can walk through it
In the diagram below, if this is your setup, modem has to be on Bridged Mode:
Phone jack --- modem --- Linksys Router --- computer
Oct 18, 2010 | Linksys Wireless-G WRT54G Router
Bridge router
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Jun 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
New modem & nowI cannot acces the internet or email. I got a new
Reset your router and reconfigure your router as per the new modem settings or else you can contact your isp after the router reset.
Jun 03, 2010 | Linksys Wireless-G WRT54G Router
BRIDGING MODEM AND ROUTER
Your firmware may not support bridge mode, try installing dd-wrt from http://dd-wrt.com/dd-wrtv3/index.php
Aug 19, 2009 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT54G router. The power went out the other day and I haven't been able to establish a connection since. I can connect when I run cable from the modem to the cpu, but not if I try using...
what is the model of your modem? if you said that you are able to get online when your computer is hooked up to the modem only, then it indicatest that your modem is not yet in bridge mode. Putting it in bridge mode will make your modem a "pass through" device thereby causing no conflicts in asking for ip add/connecting to your ISP. when your modem is in bridge mode, you should not be able to get online.
after setting your modem to bridge mode, connect your linksys router. if you have a pppoe connection, or one that uses username and password, have that set up in your linksys router. at this point, your router will be the one to ask ip adds from your ISP.
you could also visit this site, http://www-ph.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=PH/Layout&cid=1166859677881&pagename=Linksys/Common/VisitorWrapper&lid=7788193882H13, for further configuration of your router. as for your modem, try to call your ISP on how to set your modem to bridge.
May 05, 2009 | Linksys Wireless-G WRT54G Router
Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
How to put dsl-320T in full bridge mode?
You could install Router Techs firmware on your modem www.routertech.org and it would give you the option to put the modem in full bridge mode. However I'm not sure the hardware on the modem fully supports it. You might have to use half bridge mode and let your router do the DHCP.
May 18, 2008 | D-Link Computers & Internet
Efficient Networks SpeedStream 5200 Modem Logo
241 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
