Question about Dewalt D55270 gas powered air compressors
Tried to start and would then checked oil seems gas is going into oil what could be wrong
  • Dewalt Master
  • 885 Answers
This is caused by a problem in the carburator, usually the needle valve is stuck open letting gas continue to flow into the motor even when the float bowl is full. Things to check for are that the float is still in tack and floats on the gas so it can close the valve. More likely there is something stuck in the needle valve holding it open. If the needle valve tip or seat is damaged it can also cause this problem.
Posted on Mar 11, 2011
How can i diagnose whether my cts or tbs or pcm is bad on my 2000 saturn sl2
Fuel pump testing should be done before assuming anything . An disconnecting O2 sensor is not going to do anything . Is there a security light lit on the instrument cluster ? Anti- theft system problem . Your best bet would be to have it towed to a qualified repair shop instead of guessing what's wrong a just replacing parts .
Mar 28, 2017 | Saturn SL2 Cars & Trucks
17 hp briggs smoking badly . found oil in gas. took head off cleaned valves and piston. took off carb and checked float. checked breather seems ok. starts right up. littlesmoke then more as it warms up...
The only way oil can get into gas is if someone adds oil to the gas! Drain gas tank. Put Clean gas in and try it then. Oil in gas usually fouls the plug so if it doesn't run by now, check the firing in the plug.
Dec 16, 2011 | Measuring Tools & Sensors
We have a 2001 Nissan Altima. It has been a very good car. We were driving one day about a month ago and trying to accelerate, the car wouldn't go. It seemed to bog down when you mash the gas. We...
For a free check on your code,go to Autozone and they will scan your code for free and it only takes a minute and they will tell you what's wrong.When was the last time you had your oil changed.You can take it to the Nissan Dealership for a oil change and they will see the check engine light on and run a free scan and tell you what is wrong and how much it will cost.They always check customer's vehicle's out to see if it need's anything.
Jun 02, 2017 | 2001 Nissan Altima
At starting my car seems like it not getting gas!
plz check ur fuel pump..n try to service ur fuel injection
Sep 17, 2009 | Mitsubishi Outlander Cars & Trucks
Echo gt 2000 wont start
Mix the fuel/oil ratio an ounce of two cycle oil to a quart of gasoline or 4oz of two cycle oil per gallon of gasoline. I don't think that the fuel mix is the problem though. Check the screen at the exhaust port and clean out any carbon build-up found there. I would clean or replace the in-tank fuel filter as well. Anyway, hope this helped and best wishes.
Aug 18, 2009 | Craftsman 25cc Gas Line Trimmer
1996 chevy cavalier
get a friend with a working spedo on the phone driving next to you talk about your speeds
Feb 10, 2009 | 1996 Chevrolet Cavalier
Car sounds like it wants to turn on but doesnt
i think you need to change yr fuel pump
Dec 16, 2008 | 2003 Chrysler PT Cruiser
Oil pressure
It sounds like the oil pump is getting weak and you need a tune up from the information you gave. But before you pull up the engine to get that oil pan off, check the oil pressure switch. The oil pressure switch will send a false signal to the ecm when it starts to go bad and it will in turn throw other sensors off. It can also cause too much gas to go through the fuel system and find its way back into the oil pan. Hope this helps.
Jun 08, 2008 | 1989 Pontiac Firebird
Dewalt D55270 gas powered air compressors Logo
76 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
