Question about Samsung SCX-4100 All-In-One Laser Printer
Can't scan documents
Just moved and lost the cable that connected my printer to my pc during my move - went and bought a new one - can print - but cannot scan documents - error message "Port is disable. Ensure that port is properly connected & power is on, then restart computer"
I uninstalled all Samsung files and then re-installed
still can't scan - error message now "cannot open device"
Need to know what is wrong with my Samsung SCX-4100 - help please!
  • hinduhustler Aug 05, 2008
    I am having the same issue where I am unable to scan documents using the Smarthru application. It first comes up with with "port is disabled. ensure that port is properly connected and power is on, then restart your computer" error message. After clicking okay on that it proceeds to the cannot open device error. Any help is appreciated, thank you.
For the system to work completely; you need the print driver, scan driver and smarthru4.
Once you install the scan driver (available on Samsung website); the issue will go away.
Also, another trick; instead of using the smart thru - which is kind of awkward, download Picasa 3 and if you have installed the scan driver correctly, you can use Picasa to import the scans by controlling the printer. It also allws for some other tweaks that are not so easy to get to in Smart Thru.
In addition to Picasa you can use several other graphic applications to scan the image.
Good luck.
Posted on Jan 26, 2009
When I try to do a prescan I got the error message "Can't open SCX-4100 series"
Posted on Sep 29, 2008
    New Friend:
Hi - When i click on "pre scan" button , it says "System locking....please unlock and press c button to continue ".
Kindly help me what I should do next.
I am using OS win 8.1 in my HP 15 Notebook PC.
Any solution is greately appreciated.
Pls respond asap. - ramya.rbalan@gmail.com
Posted on Aug 12, 2014
My Samsung SCX-4100 Laser Printer Scan Cable cut by the Mouse. Printer Sow massege is Scan error. I want new cable purchase. Cable No. is M 20861 105C 60V Plz Sent me Service Center name which provide the cable. I leave in Bikaner (Rajasthan) My E-mail Address is gyanendrasingh_2003@yahoo.co.in
Posted on Sep 23, 2008
    Sniper:
  • 60 Answers
THIS IS THE SOLUTION:
Samsung SCX-4100 is connected to te PC trough paralell port LPT. (not USB)
You must go in BIOS (most computers acces BIOS trough pressing DELETE-button during start) and select "Integrated Peripherals ", there you can see your LPT printer port.
If the port is disabled, enable it.
If already enabled, it is set to standart features. Highlight that settings, press ENTER and choose EPP/ECP feature.
Most parallel connected printers and scanners made since about the early 90's require EPP or ECP mode, or they aren't recognized as being connected at all, or you get strange error messages
Then press F10 for saving, then "y" for saving and exiting BIOS and the scanner will work for sure on your computer, too!
Enjoy and rate the answer!
Posted on Oct 28, 2010
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
How do I set up the scanner on my HP J3680?
use the CD that came with the printer.it has the full feature software that will enable the printing and scanning capability of the printer.
- insert the disk in the CD-ROM drive - hit install - reminder:do not plug in the USB cable yet unless you are prompted by the installer to do so - after installing the software , make a test print to prove the functionality of the printer. - then we move on to test the scanner -there are two ways to make a scan: 1. click on the solution center icon on the desktop. 2. in the solution center , there are two buttons for scanning: scan pictures and scan document 3. scanned documents are saved under the MY SCANS folder. file path is : my documents or simply documents---->MY SCANS 4.for scanned pictures file path is
my pictures or simply pictures---->MY SCANS
Jun 27, 2011 | HP J3680 Officejet All In One Printer
Whenever i try to print anything my printer prints the first 5 lines or so and then just stops and moves on to the next page where it print the first 5 lines before giving up again.
What type of document are you trying to print(PDF, MS Word doc, etc)?
Is the printer connected via USB cable, Bluetooth?
First thing I would do is try printing a different document or even a different type of document.
If printing different documents results in the same problem then I would uninstall the current drivers, download the latest drivers from Canon, then install those drivers and try printing again.
Also, if the printer is connected to your computer via USB cable verify the cable has no exposed wiring or try a different USB cable.
Mar 12, 2011 | Canon MP610 Photo All-In-One Printer
I recently moved my computer and printer. I have an older HP K60 all in one printer/scanner/fax. After the move I had to reset all print functions but when I attempt to go to the director on my pc, it...
Hi This link will show you the step by step on how to rectify the problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00112149&cc=us&lc=en&dlc=en&product=59273&tmp_track_link=ot_search
Hope this helps
Mar 06, 2011 | HP OfficeJet k60 All-In-One InkJet Printer
When I unplug my 2610 printer to move it then plug it back in, it does not work. Twice before this happened and somehow I fixed it when it went to the print wizard. This time, I cannot fix it. I downloaded...
First disconnect the printers USB cable from the PC. Go to the control panel and open add or remove programs. Find the installed software for your 2610 printer and select to uninstall the software. When completed restart the PC. Install the latest software for your printer from HP.com and during the installation it should prompt you when its time to connect the printer. When prompted, connect the USB cable from the printer to the PC and power up the printer. You should see a message indicating that your computer has found new hardware and is installing the necessary software to complete the installation. Call HP support if these steps don't resolve the issue.
Oct 29, 2009 | HP Photosmart 2610 All-In-One InkJet...
PSC 1315v won't print
When you go to scan and the power light flashes, that tells you your computer IS communicating with the printer, however it may not be a good connection. Below i described that more. If the connection is indeed fine, and you tried a second pc or re-installed software completely, then I would have to say the printer is dead to you. (ie. a chip on a logic board has failed). Please continue below.
Software may be at fault. Can you print a demo page on the printer? Generally it can be done without a computer connected even, just hold any large buttons on the front of the printer for a few seconds, lights should start flashing, and a test print should print. I bet it will, because you said it "copies without a gripe."
IF that works, maybe you can completely un-install the printer software from Add/Remove Programs, or you can install it on a second computer?
IF that does not make a difference, try a new USB cable if you can. OR See if the USB port on the back of the printer appears loose. Are you able to hold it upwards or downwards or move it around at an angle? You could print another page, and quickly hold the cable in, and pushed up at an angle, or pushed IN-AND-DOWN at an angle.
IF that can be confirmed, you would need a $1 store soldering iron and would have to take the printer apart, and heat-up the connections between the USB port and the logic board. Possibly need $3 of solder from radio shack or what not. Hope I
Sep 07, 2009 | HP PSC 1350v All-In-One InkJet Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
2,279 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
