Question about Saeco Starbucks Sirena Espresso Machine
My Sirena hot water/steam knob does not engage, it just turns.....turns....turns
  • 2,382 Answers
Hi, here is how you fix it.
There are screws behind the water tank. Once these 4 screws are taken out, you can take off the top heat plate of the sirena. Then there are more screws holding down the outerlining from which the heat plate rests on. Take these screws out so that you can take out the outer lining. This will give you full access to the part you need to work on.
Once the machine is open you will need a small allen wrench to tighten the specific part that has come loose. It attached to the axle from which the knob is attached to. Its a metal part that resembles this picture at this LINK........
On this part there is a small screw that needs to be tightened so that it controls how far the knob can turn. When this part spins along with the axle, it will hit a stationary metal block that keeps it from turning too far. You will have to mess with the mechanics of it to figure out what I am talking about.
Posted on Mar 11, 2011
Sirena Espresso Machine powers on but will not heat up and water not priming
After weeks of trial and error, I have found the solution, to prime the Starbucks Sirena Saeco Espresso Machine (woohoo!!!!!!!!!! ). You do not need to disassemble this machine, it will not heat unless it is prim WARNING: machine must be STONE COLD before attempting this! 1. Get a large syringe (Without a needle of course, I used a 60ml one I bought at a pharmacy for $3.) 2. Fill the water tank full 3. Pull off chrome tip on the steam wand to expose the black plastic jet where steam comes out. 4. Place the tip of the syringe onto the tip of the black plastic steam jet on the machine. 5. Push the power button ON. 6. Turn the steam knob clockwise all the way until the pump starts. 7. Press the syringe onto the jet firmly to seal the connection, and simultaneously draw the plunger out. 8. Quickly, release the seal and eject the air in the syringe out (into open air not into the machine) 9. Repeat steps 7&8 until water draws into the syringe. 10. Go make yourself a cup of coffee and celebrate that you overcame the flaw in this machines design that renders most of them to the rubbish heap.
Jul 12, 2015 | Saeco Starbucks Sirena Espresso Machine
My sirena has blue blinking water light even though it has a full amount of water
Turn on the machine and turn the steam knob all the way on. Let it run until the light goes off. This primes the pump. It should run properly after that.
Oct 01, 2011 | Saeco Starbucks Sirena Espresso Machine
The hot water steam knob on my Sirena espresso machine no longer engages to prime or steam. It just turns and turns and turns....
I had the same problem. Here is how you fix it.
Once the machine is open you will need a small allen wrench to tighten the specific part that has come loose. It attached to the axle from which the knob is attached to. Its a metal part that resembles this picture at this link
http://www.rceasy.com/wp-content/uploads/2008/08/servo_arms.jpg
On this part there is a small screw that needs to be tightened so that it controls how far the knob can turn. When this part spins along with the axle, it will hit a stationary metal block that keeps it from turning too far. You will have to mess with the mechanics of it to figure out what I am talking about. Hope this helps and good luck!
Jan 26, 2010 | Saeco Starbucks Sirena Espresso Machine
Unable to prime Sirena Espresso Machine
n regards of the no prime issue. this is the only way i could prime this new puppy.make sure its stone cold which is a no brainer since it will not heat h2o unless its primed. first take off steamer plastic tip ,turn on steamer clock wise till pump starts. then **** the tip of the end of the metal tip hard until pump stops may need to do it a couple of times. yes this seems out of this world but it works. you are flushing out the vapor lock in the pump. bravo enjoy!
Nov 28, 2009 | Saeco Starbucks Sirena Espresso Machine
Just out of the box, the sirena espresso maker doesn't heat and buttons don't flash
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 15, 2009 | Saeco Starbucks Sirena Espresso Machine
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
Steam wand doesn't work
High pressure air using a blowgun?
Aug 24, 2009 | Saeco Starbucks Sirena Espresso Machine
Starbucks Sirena. lights blink, won't heat.
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Jun 10, 2009 | Saeco Starbucks Sirena Espresso Machine
My sirena does not work
anytime the water runs out and you need to refill the tank, you need to bleed the line so to speak. Take an empty cup and put it under the wand and open the knob of the steam wand until the blue light stops flashing
Feb 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Starbucks Sirena Espresso Machine Logo
66 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
