Question about Music
How do you save a patch to existing file? - Music
Oh you rigth, but in this model, the pc board is sanwich of 3 layers: 1layer top, 2layer back and 3 layer inside. unfortunatly, the coneccion between the dc input and the components is for the internal layer, I think, the better is to conect for a low resistor outside between dc input and battery
Posted on Mar 11, 2011
Will a midi interface allow me to play downloaded music on a yamaha clainova 305
Yes, with some preparation. The music will have to be in a standard MIDI file format or a format that results in standard MIDI over USB output when "played" by computer software or an external sequencer. Within the software you will probably need to create a new "instrument" if there is not already a template for the CVP 305, otherwise the tracks and sub channels in the MIDI file will be patched to GM, probably not what you want to hear.
Aug 29, 2017 | Yamaha Music
Tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
on Feb 25, 2015 | Roland Boss RC50 Loop station (with )
How do I install patches?
Download n install 2 softwares for G2 from ZOOM website.
1. USB subsystem. Driver to connect zoom fx to PC/Notebook.
2. EDIT & SHARE. Software to create/copy sound patch.
Connect USB cable from G2 to PC/notebook.
No need adapter power supply, because the power is supply via
USB cable from PC/notebook.
Open EDIT & SHARE. It's easy,like copy,paste,rename,delete etc.
Just open the menu that you want to do and follow the
instructions. Sound patch can be load from files that you
download, or create it in EDIT & SHARE.
Patch can be load one files or group. Right Click the sound that you want to change,copy-paste it from new file/sound.
You can import/export files/patches from/to PC library (downloaded files).
It is recomended that you save/backup your original files,before load new sound.
I hope this helps.
Regards.
Aug 31, 2015 | Zoom G2 MultiEffects Guitar Pedal
I have Zoom G1XN ext. My guitar effect just lit "Gn" and can't change to Bank memmory. I need the circuit diagram and service code for Zoom G1XN ext whom can help and send to my email dias.no1@gmail.com
Have you tried to reset the unit? You can do this by holding save button for few seconds while connecting your adaptor to g1x/g1xn. Then the indicator will blink, then push save button again,this will reset your unit into its factory settings
Jul 12, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
My behringer djx700 5 channel pro dj seems to have a feedback problem even when nothing's plugged in to it cant figure it out.
It doesn't seem like a typical "feedback" problem, as feeback is produced by over modulation between the amplifier and the source - usually a pickup or microphone. It may be your cables to your amplifier are bad, or the actual line out jack(s) may have gone bad. If it is more of a humming sound rather than feedback, that is most likely your issue. If you have additional patch cables, switch out the existing ones, and see if that ends it. If not, it is possibly the jack(s).
You have a headphone jack on the Behringer, though you did not say if the problem arises through the headphones or an external amplifier. If you get the noise in the headphones, when no patch cords or a mic is attached, then the problem you should look at is your headphones or the headphone jack. You can narrow the problem down by using an external ampifier and see if you still have the "feedback" sound. if not, it's in the headphones or headphone jack.
Please try and provide more information for this question if we are unable to track the problem with these suggestions. As we do try very hard to center in on customer's problems, we do ask to provide as much information as possible, so that we can facilitate your resonse more effeciently.
Thank you for using FixYa.
Dec 31, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Cant import WAV files
Did you look here under support:http://www.bossus.com/gear/productdetails.php?ProductId=772# Also there is an update available under downloads. The Preset Protect function protects factory patches at locations 1-5 from being overwritten. It is shipped with the demo audio saved there and the preset protect enabled. Here is the manual for creating patches:http://cms.rolandus.com/assets/media/pdf/RC50WS03.pdf The rest of the manuals are under support. The manuals have hot links to each other for various subjects. You can reach their product support dept. by phone or email. There is a knowlege base with answers to questions about problems other owners have:http://www.bossus.com/gear/productdetails.php?ProductId=772#
Aug 30, 2009 | Boss Rc 50
How To Turn Drum Beat Off
From what I remember from my recent tinkering you press the guide select button. Then either use the patch/value know and parameter buttons, OR it may be the guide level knob to switch the volume down until it is off. I believe I then saved the patch to preserve the setting and keep that irritating guide at bay! It really should be more intuitive, ideally knod turned to zero = OFF. But no. Ah well, hope you get it sorted. I have a problem too, maybe you have same one? It may be the unit itself. Search - Beggining of loop missing on FIRST playback - if you get a chance. Let me know if yours does it too?
Mar 06, 2009 | Boss Rc 50
RC-50: Importing wav. files from computer to loop station.
Hi I just got a RC 50 and I face the same problem but looking the content of the data in the Roland folder (after you connect the USB) , I notice the format of the label of each sound's and I understood the problem. So , here it is . Before you connect to USB , you have to choose a patch , let say n.16 OK, now the audio file that you want to import into the data folder must be named in this way "016_1.WAV" ,the 16 refer to the patch number and 1 is the phrase number (if you want to put the audio file into the phrase 1 ,or 2 if 2 ecc.) now disconnect the USB .At this point you just have to increase or decrease the patch number just one time and go back to 16 (it has to refresh the patch info) and you'll find your audio file ready to use in whatever phrase you put it.
have fun
Paolo
Jan 19, 2009 | Boss Rc 50
Music Logo
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
