Question about Toys
Can't get bumble ball apart to put in new batteries-any suggestions?
How do I report finding metal in bumble bee tuna
your local government department for health, the manufacturer, radio stations , media , local hospital
Feb 03, 2018 | Baby Gear
How do I lubricate squeeking ball bearings
You dont, if the ball bearings are bad they need to be replaced, all pool motors ball bearings should be sealed. Taking apart the motor to get to them is a bit much for most people. First find the make and model of your motor how many ball ball bearings there are and find somebody that sells the ones you'll need. There's usually 2 and you'll have to take the front and the back of the motor apart to get to them and replace them. See attached what one looks like. Also if you do this yourself and take the motor from the pump its a good idea to replace the pump shaft seal as it usually leaks and easier to do while your putting it back, rather than after you put it back and it leaks.
Nov 21, 2015 | Pool & Spa
Wrong ball stuck in trunk of playskool ball popper
Search results brought me here in hope of finding location of all of the screws to take the toy apart. All but 4 of the screws are visible when then toy is fully assembled. There are 2 screws behind the ears (pull them away from the head, as they simply snap in place) that require a long shank phillips screwdriver to reach, and the other 2 hidden screws are behind a removable rear base adjacent to the battery compartment That one also snaps into place. Once all of the screws have been removed you can easily separate the front half from the rear half. In my case, there was a bread tie stuck in the fan. No amount of fishing would have removed it. Cheers!
Feb 05, 2012 | Playskool Busy Ball Popper
I got it from someone without a ball and a battery and put new ones in it and tried to charge it but it won't charge
If the cell phone was taken apart without careful tact taken while dismembering the phone, you could have broken a transistor on the internal board of the phone. The other issue could be that the phone's internal memory needs to be reflashed with the OEM phone software. What type of phone is it?
Mar 21, 2011 | Cell Phones
The dryer Zanussi ZD100 C makes much noise as an old truck. It bumbles and sound like thunder. It heats all right. The blower is ok. I wonder how to take it apart as the back and sides are connected...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 16, 2010 | Zanussi TD4100W Electric Dryer
Shifter linkage came apart from transmission shift arm
I had the same problem and also linkage inside the car. I took ball joint apart and cleaned the surface then put silicone inside ball joint. Joined the two together then I put plastic tie wraps for wiring around the ball joints, two per ball joint. Let sit for 24 hours and it worked. It is probably temporary but it got me out of a $165 an hour repair job 500 miles from home. Hope this works for you as it tightens up the linkage and worked great. CW
Mar 24, 2009 | 1996 Chevrolet Cavalier
8100 rollerball wont scroll down
sounds like the ball is gummed up.. there are several sites that will show, with pics, how to remove the ball assembly and tear it apart to clean it... but be careful.. it is not as easy as it looks.. i ended up buying a new ball off of ebay for under $12 shipped.. so i suggest that route
Dec 31, 2008 | RIM BlackBerry Pearl Smartphone
TI-83 Plus Went Dead
Has it been dropped recently? The screen may have cracked from impact. Press the Reset button on the back using a ball point pen.
Nov 16, 2008 | Texas Instruments TI-84 Plus Silver...
BlackBerry 8100 Pearl
You can order a replacement trackball at www.blackberry8100parts.com for $9 its easy to install
Jun 02, 2008 | RIM BlackBerry Pearl 8100
Toys Logo
180 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
