You need to check the head unloader.
Compressed air that is trapped over the piston when the compressor shuts
off will be evacuated to atmosphere through the unloader valve, to
prevent that compressed air pressure from adding load to the start up of
the compressor motor, when the pressure switch again calls for air.
For example, the last time you did a sit-up, you may have folded your
arms over your chest, or if you are particularly masochistic
even held a weight to your chest. What you were doing is increasing the
load against which your muscles have to work to effect the sit up.
Compressed air, captured in the cylinder after the compressor shuts
off, would increase the load against which the electric motor would have
to work. It may increase the load too much, and the motor may fail to
start, or it may pull too many amps and fry a fuse or pop a breaker in
the panel.
When the compressor shuts off, the unloader valve operates, it
unloads the trapped air to atmosphere, and that problem is solved.
The unloader valve is plumbed somewhere in the line between the compressor and the compressor tank.
It is often part of the pressure switch assembly. It will, in many
cases, be opened by the pressure switch, when the air in the compressor
air tank reaches the set point and the pressure switch trips the power
supply to the motor off, and at the same time, trips the unloader valve
to open.
it is normaly on the bottom of the pressure switch it will have a small tube hooked to it
