Question about Seiko Hc500 Protape 16' Electronic Tape Measure
After Replacing The 9 Volt Battery I'm Getting An Error On Display
Error code 9 accu check meter Replaced battery still error 9. Also, strips are in date.
The only way to tell that the new battery is good is to test it with a volt meter. There is no way to tell how long a battery sat in a warehouse before it was moved to a store and sold.
Feb 24, 2017 | Health & Beauty
Transformer AC 9 Volt, battery 4x 1.5 Volt DC. On
first is no i would not recommend feeding the 9 volt dc through the actual 9 volt ac it may damage the bridge rectifier that converts the ac to dc
Aug 08, 2013 | Sangean ATS 909 AM/FM/SW Radio
Turns on play and drops voltage to 9 volts
How old is you battery? If the voltage turn down to 9 volt mean the battery has low current. If your battery is 1 and 1/2 years or higher your need to replace it. The battery last only for 1 years onward if you use your car occasionally. One of the plate in your battery is damage. Try to borrow and new battery to test it first before replacing it. Then check if still dropping the voltage. Did you check your regulator on your amplifier, if the input is 12 volts or more the battery is good and in the output goes down your check it 9 volt your problem is in the regulator. Bypass the regulator check it to sure the if the voltage still dropping. if not dropping the regulator is the problem
Sep 27, 2011 | MTX Thunder5601 Car Audio Amplifier
Thermostat going dim
Try replacing the 9 volt battery in the thermostat. Clean the terminal with a #2 pencil eraser to get rid of any corrostion.
If that isn't the problem, then something in your thermostat is getting ready to fail and pulling more power which makes the light dim. Unfortunately, the boards are not usually locally avaiable and will need to be ordered, so you might want to consider replacement versus repair.
Aug 28, 2011 | Honeywell Electronic Programmable...
I lost the battery charger for the BigFoot toy. Can I buy one?
I know you can get these on Ebay. Also most NI-MH 9 volt battery charges will charge this battery pack. You can use a 9 Volt Snap Battery Connector with Alligator Clips to bridge the connection between the battery pack and the NI-MH 9 volt batter charger. This is how I charge this battery pack now. You can probably get the 9 Volt Snap Battery Connector with Alligator Clips at a radio shack or on Amazon... as well as a NI-MH 9 volt battery charger.. don't hook up the leads backwards :)
Aug 10, 2011 | Mattel Fisher-Price Imaginext Big Foot
How do you connect a HP compaq fan to a 9-volt battery?
  • Remove the 9-volt battery to be tested from the device it is powering.
  • 2can-test-9v-battery_-1.2-120x120.jpg The Readout image by Cinneman from Fotolia.com jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a06/vk/ld/can-test-9v-battery_-1.2-800X800.jpg'); }); Test a battery with an inexpensive voltmeter or battery tester.
    Read the instructions of the testing device to ensure an understanding of how to connect the battery to the tester properly.
  • 3
    Attach the battery to the testing device according to the manufacturer's instructions, being careful to attach the positive terminal of the battery to the positive input of the testing device, which will be indicated by a "+" or "positive." Attach the negative terminal of the battery to the negative input of the testing device, which will be indicated by a "-" or "negative."
  • 4can-test-9v-battery_-1.4-120x120.jpg battery tester on white image by JoLin from Fotolia.com jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a06/vk/ld/can-test-9v-battery_-1.4-800X800.jpg'); }); Battery tester with metered readout display.
    Read the display of the testing device to determine the status of the battery. If the voltage is low, replace the battery with a new one.
    The electrical output of a 9-volt battery will decrease slowly until it reaches a level that is no longer adequate to power a 9-volt device. When the output of the battery decreases to 5.5 volts or less, the battery should be replaced as the power output has diminished to a point of imminent failure.
  • Oct 24, 2010 | Computers & Internet
    Kenmore freezer depleting 9 volt batteries, setting off alarm
    trojo50,
    your defrost elements are not working or the water inlet for the evaporator tray is clogged. That alarm is to let you know something else has triggered it. This could be s imple DYI solution or require a service call. let me know if you are up for the DYI.
    randy320sgi
    Feb 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
    My casio exilims battery charger light is flashing, i know theres a trick using a 9 volt battery. how can i do it?
    you take a 9 volt battery and take a metal paper clip or anything this and metal and connect it from the + side of the 9 volt battery and the - side of the camera batery. take another mateal object and connect it from the - 9 volt battery to the + of the camera battery. hold it for about 30 seconds (it might be easier if someone helps you) and place the camera battery back in the charger. that should give the camera battery enough power to help it boost up its charge and make the flashing stop
    Dec 10, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
    Reverse Sensing System doesn't sound
    To test the speaker touch the wire terminal a 9 volt battery tester, make this by soldering wires to any 9 volt battery, then touch momentarly the battery leads to the speaker, the cone will move and make a slight pooping noise.
    Oct 16, 2008 | 2005 Ford F-150
    Not charging battery
    hold a 9 volt battery to the camera battery for about a minute or so, + to - and - to +.
    i bought one that was from a display and had the same problem. i learned this trick in electronics class in school. it works, made mine charge.
    good luck
    Jul 27, 2008 | Casio Exilim EXZ75 Digital Camera
    Seiko Hc500 Protape 16' Electronic Tape Measure Logo
    49 people viewed this question
    Top Seiko Measuring Tools & Sensors Experts
    Vuk B
    Tom Chichester
    Are you a Seiko Measuring Tool and Sensor Expert? Answer questions, earn points and help others
