Question about Konica Minolta Office Equipment & Supplies
How do i replace the waste toner box on the konica minolta
  • 34 Answers
When you open the door to access the toner and waste toner area, you will see a letter "K" on the left side of the waste toner box, and a thumb screw on the right side of the waste toner box. Immediately above the letter "K" there is a raised area in the brown plastic housing. It is between the blue toner cartridge, and the waste oner box. There is a second raised area 2.5 inches at a 225 degree angle below the thumb screw on the right side of the waste toner box.
If you will place your thumbs on the raised areas and your forefingers on the white plastic rear cover of the waste toner box immediately below the raised areas and squeeze your fingers towards your thumbs, the waste toner box will come forward at the top of the box. You can then lift the waste toner box up and out of the printer.
Please squeeze carefully if you think your waste toner box is close to full as you may inadvertently find waste toner all over the place.
The two blue caps on the back of the waste toner box are to keep the waste toner in the waste toner box instead of your carpet.
Installation of the new waste toner box is the reverse of the above procedure. The new waste toner box almost snaps in place.
Here in California waste toner is considered a hazardous material and must be disposed of properly.
Posted on May 14, 2009
5 Suggested Answers
otacon
  • 1944 Answers
SOURCE: Konica Minolta 2300DL waste box full message
Did you try disconnecting the printer for a few hours to hard reset?
Posted on Mar 22, 2008
Kevin Hayes
  • 167 Answers
SOURCE: C250 Waste toner
Actually you are supposed to replace the whole container.
You can order this as part of your service contract just like toner, the cost would be included.
If you are shaking it out, be aware it is VERY flamable in such a fine powdered state.
Posted on Jun 06, 2008
  • 9 Answers
SOURCE: changing toner in a konica minolta 2480MF
http://kmbs.konicaminolta.us/productsattachments/manuals/magicolor2480MFUserManual.pdf
check page 92-101 in pdf or 82-89
hope this works
Posted on Nov 20, 2008
CANTUSMELLTH
  • 3 Answers
SOURCE: can't make machine print Konica Minolta 2300DL
As soon as you open the door on the right side of the unit the waste collection box is there. You will see it, it is the large strangely shaped item that extends from the middle top to the bottom of the unit.
Posted on Jul 08, 2009
I have Konica Minolta C652. I emptied toner box & placed it back but then the screen is telling me to install toner box & close all doors.
In the middle of the Box there is a see thru dark plastic , a lip , that goes inside the the sensor , when the box gets full of toner it blocks the light that goes thru it, when you emptied the box the plastic inside was still dirty, Replaced box or clean the box from inside
Dec 17, 2014 | Konica Minolta Office Equipment & Supplies
Reset konica minolta c35
first replace the waste toner box you do not reset.
May 09, 2014 | Konica Minolta bizhub C250 All-In-One...
C452 water toner
replace the waste toner box lower section below toner section is in front of the image units
Apr 30, 2014 | Konica Minolta Bizhub C452 Copier
Error code c 2204 on konica minolta c652
Waste Toner Motor failure. check the waste toner box might have a issue where harden toner damaged the gear drive and or motor that takes care of the waste toner. worse case the control board is damaged $$$$$$$$$$$$$$$$$$$$$$$$$$$$. Have a tech come out mite require replacing some gears.
Jan 22, 2014 | Konica Minolta bizhub Office Equipment &...
My konica minolta 2300dl tells me my drum is low. do I need toner? Where do I go to get toner?
If it tells you the DRUM is low it has nothing to do with toner, it probably meens you need to replace the DRUM unit (aluminium blue/green cylinder in the device) dont forget to reset the timer after replacement
Jan 04, 2011 | Konica Minolta OEM Konica Minolta...
What does trouble code C-2204 mean on our Minolta C451
this is a waste toner box error the waste toner box could be defective or the full sensor is defective i would start with replacing the waste toner box and clean the sensors on the door with some canned air the waste box and the sensors are located inside the lower front door the instructions on how to remove the waste box are on a label on the inside of the door
Dec 01, 2009 | Konica Minolta bizhub C250 All-In-One...
WHERE IS THE WASTE BUCKET ON PRINTER KONICA 4690MF
Found this on the support site
When the waste toner bottle becomes full, the message "WASTE TONER
FULL/REPLACE BOTTLE"
Konica/Minolta Support
Go to "Ch. 7 replacing consumables" > "Replacing Consumables" > "Replacing the Waste Toner Bottle" this is found on page 165 of the user guide. This walks you through replacing the waste toner bottle.
Hope this helps. GOOD LUCK!
Oct 16, 2009 | Konica Minolta Magicolor 4690MF...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
Oct 31, 2007 | Konica Minolta bizhub C450P Laser Printer
2,400 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
