Question about Canon PIXMA MP160 All-In-One InkJet Printer
I have a Canon Pixma160. I get a white line through the printing. I've tried fine and deep cleaning. White line is still there. How do I get rid of the white line?
  • lasertek Dec 19, 2012
    You might want to clean your print head and transfer roller. If after cleaning, the result is the same.Try changing your toner cartridge. Learn other basic troubleshooting here.
    New Friend:
  • 39 Answers
You might want to clean your print head and transfer roller. If after cleaning, the result is the same.Try changing your toner cartridge. Learn other <a rel='nofollow' href="http://www.printerquickfix.blogspot.com/">basic troubleshooting</a> here.
Posted on Dec 19, 2012
  • 604 Answers
You have a bad print head (some printers have them built into the printer ink cartridge and cannon is one that does, what this means is thay you have a bad ink cart and need to replace it.
Posted on Mar 10, 2011
White lines on dark photo prints
White lines means some of the print head nozzles maybe blocked.
Try the deep clean print head cycles then do a test print. If this still does not fix the problem then a new print head is required.
Print heads are expensive and if your printer is old then maybe better to put your money towards a new printer.
Oct 18, 2012 | Canon MP560 All-In-One InkJet Printer
White lines in my printing and sometimes smudges of black ink
Hi
First before you buy a new cartridge,try doing a 'printhead' cleaning on your machine.Sometimes the printheads need cleaning clogginl.
Mar 03, 2012 | Office Equipment & Supplies
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA iP3000. I have completed a nozzle check, but have odd results... BLACK-Perfect CYAN-4 EQUALLY SPACED WHITE LINES...NO DROP OUTS PALE CYAN-PERFECT MAGENTA- 4 EQUALLY SPACED WHITE LINES...NO DROP...
Inkjet printers do not like being left unused for long periods.
Some of the color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 17, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
My MP830 leaves white horizontal bands when printing black & white documents. Color printing seems fine. Pattern 'F' is missing on the print alignment page.
You need to continually clean and deep clean and realign the black until the results are acceptable. Try manual alignment if the auto does not work. Also clean around the exit hole of the black ink cartidge with a cotton bud and isoproyl alcohol.
Nov 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon i500
ur cardige has damged change the cardige of your printer & your printer problem will be solved
Feb 26, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
284 people viewed this question
old marine
old marine
