Question about Element Electronics Televison & Video
Element tv saying no signal. Have tried connection with other tvs and they work. Swithched cable still no signal
  • 8 Answers
SOURCE: LG LCD HDTV 'NO SIGNAL'
if it still under warranty get intouch with LG-if not looks like (if its definitely not your input signal) theres a problem on the mainboard- if theres a firmware fix for the issue youll have to look into as there are many forums with ppl who have problems like this
Posted on Dec 18, 2007
freetek
  • 5568 Answers
SOURCE: No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
Posted on Aug 02, 2008
  • 453 Answers
SOURCE: cable quit working says no signal
if u are using the cable input make sure u are un chanel 3 , other way to connect the cable box is thrught the video 1
Posted on Jan 17, 2009
hawk127311
  • 350 Answers
SOURCE: I have connected my PS2 to my TV using the Red,
It is possible that the RCA cable is no good. The yellow = video, the red and white = audio. The input on the TV may be bad, try switching from one input on the TV to another if you have one available. Even if you don't have a free one, remove a DVD player or something else that may be hooked up and try to hook up the Playstation to that input using those RCA wires. This way you can eliminate the port and the wire being bad at the same time. If all else fails and the PS2 works on other TVs, the only option left would be a problem with the TV you are trying to hook it up to. I have that problem on one TV I own, one of the RCA inputs (input 4) is no good. I hope this helps.
Posted on Oct 27, 2009
  • 1214 Answers
SOURCE: TV says no signal from direct tv box
Yes, something could have gotten changed.
Confirm what input connection the DirecTV receiver is connected to on the back of the TV. Using the remote, check that the TV has that input selected.
Posted on Dec 16, 2009
Xfinity tv troubleshooting
Not sure what you are trying to do, but if you are trying to connect the cable directly from the wall to the TV, this could be your problem. Comcast Xfinity is an encrypted signal that requires either a cable box or a "Cable Card" that installs into TVs that support that capability to do the decoding.
Sep 06, 2014 | LG Televison & Video
Hi tech support. My 42" Blaupunkt tv is showing "NO SIGNAL". I have tried the HDMI connection (HDMI3) with my PS3 and I've tried the AV connection with my hardrive. No avail. The odd thing is that I need...
I have a new 50 inch TV put my TVs says no signal only have one cable going in the back of the TVs my outside Ariel also got 4/1 remote control with it TVs won't work.can you help
Aug 15, 2013 | Televison & Video
Can't adjust tint in 50 HD Digital LCD TV Element
I called Element TV they said the Tint adjustment/controls on most Digital Element TVs are programmed for "Non adjustment"with digital signals:
On Large Element TVs , the "Tint" controls are used only for Analog Video and for NTSC viewing, but the controls are inoperative or blanked-out when watching PAL or SECAM digital signals (my is HDMI directly from Digital cable box).
Dec 02, 2012 | Element Televison & Video
My element electronics tv says no signal
Two things to try:
1. Connect a DVD or something else to one of the rear audio/video inputs to see if set works that way.
2. Check to make sure set in menu is set to tuner and cable---if the tuner in the set is bad a cable box with audio/video outs on the back can be hooked to one of the rear audio/video inputs and will bypass the tv tuner--you will stay that input to watch TV and change channels with the box----
The cost of renting a box is minor compared to having to replace the tuner in the set.
Mar 24, 2012 | Element Electronics Televison & Video
My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
Jan 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Only getting blue screen on both tvs. one keeps saying no signal but have checked all cables but cant solve prblem. other tv says scan channels but i have scanned channels.
New TV's or new problem? If these are new TV's it could be that they are set on something other than the Cable Input Option.
On your remote press the input button to get an onscreen menu and set them to cable.
Otherwise, if you installed these yourself recently, recheck all connections to make sure they are set up correctly, using the manuals that came with the TVs. My guess is that you may have connected them incorrectly to/from the cable input device.
If these are not new TVs and this is a new problem, take a look at your outside cable box. Occasionally one can have a problem with an input cable. If that is the case, the cable company needs to be called to replace or repair.
Thank you for using FixYa.
Dec 26, 2010 | Element Electronics FLX2211B 22 in. LCD TV
3 PANASONIC TVS HOOKED UP TO CABLE SYSTEM AND ARE ON 37" PANASONIC TH-37PX50U WORKS FINE BUT THE OTHER 2 TVS DO NOT WORK. THE CABLE SYSTEM HAS BEEN CHECKED TWICE AND WE ARE TOLD IT IS OK BY TIME WARNER...
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Oct 31, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Hi there, my viewsonic monitor VX912 is not getting a signal from my computer. I first checked to see if the connections were good. No joy ther! so I then tried to see if the cable was faulty(my monitor...
Is your tv HD, it may have worked on the digital signal, but perhaps it switched to a HD program, and it doesnot support that HD signal, If not it may be a switching problem
Dec 16, 2008 | Evesham Computers & Internet
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Televison & Video Logo
188 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
